x 6956
Alec, PM sent.
Ohfishalee
(Donor 2022)
x 7
Unread post by Ohfishalee »
Hello. I'm searching for a blower fan, complete and the resistor. VIN VF3**************[VIN obfuscated, can be read by forum staff]
THANKS IN ADVANCE
x 6956
You'll have to be more specific:- The radiator fan and control unit or the internal passenger heating blower motor and blower control module?
But on the basis you mentioned resistor, I'll assume you meant the heating blower motor...
Item (2) Part: 6441N4, £315.68, but no longer available from Citroen
Item (4) Part: 644178, £195.83, blower motor control module.
Ohfishalee
(Donor 2022)
x 7
GiveMeABreak wrote: 08 Jun 2022, 10:14 You'll have to be more specific:- The radiator fan and control unit or the internal passenger heating blower motor and blower control module?
Thanks. Yes. I was referring to the internal blower motor and resistor.
Appreciate your assistance as usual.
x 1067
Unread post by Rp0thejester »
Okay had the car 10 years but never noticed this.
I only noticed because I lost 1.
is their a part number for this? And also what are they there for?
x 1056
Unread post by wheeler »
Its the covers for the headlamp washer jets. The part number is 6438K7 & the come as a set of 2. £57.07 inc VAT but they will come un painted.
Get a set from a breakers from the same colour of car is your best bet.
x 6956
Armidillo wrote: 07 Jun 2022, 11:41 Hi all
I have a D9 406 SV, VIN VF3**************[VIN obfuscated, can be read by forum staff], which is currently refusing to start. The starter no longer spins - best I was able to get was a very weak part-turn. This has been brewing for a while, but at first it was just occasionally, and after a few retries it would suddenly just work.
It is definitely not the battery - it's showing 12.7 volts. Just to be sure I connected jumper leads from a running vehicle - measured voltage at 13.8v - no difference.
Now I realise that there are other possibilities, but is 438087 the right starter motor? Looks like Spareto could fly one out to me for about $100 less than I could buy one in Australia.
Cheers
Alec
Hi Alec
Details as follows:
Your starter shows it being a Valeo unit (CLASSE 4, VALEO (DEMARR) - D 6 RA 107)
(1) OEM Original Part: 5802W6, £417.36
(1) Exchange Unit, Part: 1638127580, £138.86
All UK VAT inclusive and available direct from Peugeot.
Here is the diagram for the components that are showing available if you intend to repair it - just let me know which bits for the second diagram you need info for if applicable:
slackgarry
Rear hub mounting bolts Citroen C1 2008
Unread post by slackgarry »
Afternoon everyone, can you let me have the part number for the Rear Wheel bearing Mounting Bolts (4) off.
That is bearing to swinging arm.
They dont come in the bearing kit.
Thanks everyone.
Kind regards
SlackGarry
Black 2008 C1, Petrol, 1KR-FE Engine. aka the GoKart
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
And a PSA 5802W6 starter is indeed a Valeo 438087!
Thanks for the parts diagram - might look at repair later, but want to try and get this car back on the road, so have ordered genuine Valeo unit from Spareto. They claim to be able to deliver to Australia by next Friday (17th) - will be most interesting to see if they can do it!
x 6956
Re: Rear hub mounting bolts Citroen C1 2008
slackgarry wrote: 11 Jun 2022, 12:34 Afternoon everyone, can you let me have the part number for the Rear Wheel bearing Mounting Bolts (4) off.
Thanks everyone.
PM Sent
x 6956
Re: Right rocker panel for C4 GPII
eurofjr wrote: 02 Jun 2022, 20:15 Hi Mark,
I'm looking to confirm if this is the correct PN for a passenger/right rocker panel (or sill panel) for 2015 C4 Grand Picasso II, 1.6 BlueHDi, 115.
VIN: VF7**************[VIN obfuscated, can be read by forum staff].
PN that I have is: 1609352180.
Best,
Jim.
Hi Jim
Sorry about the delay - I have responded and clarified via PM.
As for the sill, no that's not the correct official Citroen part number listed on the live database. It may of course be a separate identifier, but not used internally for parts ordering.
The front driver and passenger sills are the same. Item (10), Part Number: 96767142TV, £37.22 inc. UK VAT direct from Citroen.
eurofjr
(Donor 2022)
x 4
Unread post by eurofjr »
Hi Mark,
No worries. I'd like to clarify: based on the picture, I'm actually looking for the PN for item (1) if possible.
Best,
Jim.
x 1485
Assuming yours is LHD, then yes that's the right part no, £616.96 in the UK :shock:
The other side is similar part number, but ending 380, same price.
Huskyxantia
x 901
Unread post by Huskyxantia »
Hi Marc the idler pulley on a car ive just purchased is a bit noisey its a 307sw 2.0hdi 90 if the vin is needed ill have to post it up in the morning as ive no log book yet . Many thanks
:-D
x 1056
Can get the VIN from the reg if you want?
Assuming it has A/C I suspect it will probably be 161383480 £60.41 inc VAT
