admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
GiveMeABreak wrote: 15 May 2022, 17:57 Hi Colin
Item (10) is the Bi-sensor for auto lights and wiping.
Part 6405RW, currently £300.08 from Citroen VAT Inc.
Thanks Marc.
It is working so for that price i will leave it as it is :)
Greg2791
x 5
Unread post by Greg2791 »
Hi,
Could you please provide me the part number for the Front Height Sensor. C5 2010 2.0Hdi 163HP, hydroactive, VIN VF7**************[VIN obfuscated, can be read by forum staff]. Is this the same part number for hydroactive an normal suspension system?
Greg
x 6956
Part number: 5273J4, £75.77 inc. VAT direct from Citroen.
I don’t understand the second part of your question, the C5 X7 only has the Hydractive 3+ system on hydraulic models, but if you are referring to the height correctors for metallically spring systems with directional lighting, then these will be the same.
The only other variants are for the V6 models that have different sensors ( one on each wheel).
Greg2791
x 5
GiveMeABreak wrote: 31 May 2022, 19:48 Part number: 5273J4, £75.77 inc. VAT direct from Citroen.
Thanks a lot Marc.
I was not sure when browsing the internet if the sensor is actually for my car or different version of C5. So it should be in stock.
eurofjr
(Donor 2022)
x 4
Right rocker panel for C4 GPII
Unread post by eurofjr »
Hi Mark,
I'm looking to confirm if this is the correct PN for a passenger/right rocker panel (or sill panel) for 2015 C4 Grand Picasso II, 1.6 BlueHDi, 115.
VIN: VF7**************[VIN obfuscated, can be read by forum staff].
PN that I have is: 1609352180.
Best,
Jim.
x 6956
PM sent Jim concerning Parts Data
x 1067
Unread post by Rp0thejester »
Hi peeps/Marc. Whilst replacing the starter motor, which was covered in oil, I noticed a hose which seems to of been sliced together (smaller hose forced into larger hose via a 2inch cut). It's very oily and thought that it might be the reason for the oily starter motor as it sits just above it. I've tried looking at photos online but nothing really shows the hose in question. So I took a few photos...
I believe it goes to the oil filter. Is there a part number for this? Also is it possible something else was leaking oil onto the starter motor. Thx in advance. [-o< VIN is VF7**************[VIN obfuscated, can be read by forum staff]
jamescarruthers
x 47
Unread post by jamescarruthers »
Hello all. My sister has managed to loose the fuel filler cap for her 2001 2.2 C5… it’s the magnetic type that tells the car to inject Eolys fluid so I’d better get it replaced pronto!
Can I have the part number, please, and is it still available to buy from Citroen? If not I’ll get a second hand one.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 6956
Rp0thejester wrote: 04 Jun 2022, 14:20 Hi peeps/Marc. Whilst replacing the starter motor, which was covered in oil, I noticed a hose which seems to of been sliced together (smaller hose forced into larger hose via a 2inch cut). It's very oily and thought that it might be the reason for the oily starter motor as it sits just above it. I've tried looking at photos online but nothing really shows the hose in question.
Have a look at the diagram below and let me know which item you suspect it is:
Both (5) & (9) are the Cylinder Block Oil Return Pipes.
x 6956
jamescarruthers wrote: 04 Jun 2022, 16:43 Hello all. My sister has managed to loose the fuel filler cap for her 2001 2.2 C5… it’s the magnetic type that tells the car to inject Eolys fluid so I’d better get it replaced pronto!
James, if this is for your VIN ending 665, then there were 2 options - a locking cap and a non-locking cap:
(6) Locking
Combination specified on order, part: 1508J4, £72.88
Random Combination, part: 1508J3, £101.77
(10) Non-locking was part: 1508F7, £19.09, but no longer available.
x 1067
Hi Marc, thx for the reply, I don't know how to copy your photo post. My engine doesn't look anything like that diagram. Or am I seeing it from backside of engine?
x 1067
I believe this is the pipe
x 6956
This is the correct diagram from your VIN. The other 2.2 is the 175 BHP model so different again.
This diagram below shows the oil cartridge diagram and this you can see looks like your last photo. the previous diagram I posted is to show the pipes that are not on the lubrication diagram.
x 1067
Ah, that square box confuses me as didn't notice it on starter motor change, I believe it's part no 9
x 1067
My car has had a replacement engine so not sure if VIN is accurate
