Afternoon all,
I was wondering if anyone had any advice just bought myself a 2008 2l Citroen C4 vts and was running perfect until on the way home came up with service and engine management warning.
I got home and put the code reader on it and came up with code p0121 (Throttle Position Sensor) before I look any further I was wondering if anyone here had any advice about common causes before I start looking into it
Any help would be great
Citroen P0121
- My Cars: Currently own
Citroen C4 coupe vts (2.0l petrol)
1986 land rover 90 (300tdi)
Owned
Clio sport
Standard clio
Subaru legacy
Subaru Impreza WRX
Alfa Romeo 147
3 Ford's
2 Vauxhall's
Mgf
Renualt Laguna couple
Peugeot 208
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Citroen P0121
Basically it means the data from the throttle sensor tracks (1 & 2) is incoherent. The data on tracks 1 & 2 are constantly compared with each other to ensure they are reading the position correctly. If there is an issue between each of them then this fault is returned.
Owned
Clio sport
Standard clio
Subaru legacy
Subaru Impreza WRX
Alfa Romeo 147
3 Ford's
2 Vauxhall's
Mgf
Peugeot 208
Re: Citroen P0121
Hi thank you for the information and the breakdown so is it normally the sensor that goes?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Citroen P0121
It depends on what system you have. Pop your VIN up (automasked on post submission). Most later vehicles over the last 20n years or so have the TPMS built into the accelerator pedal, so it's a new unit. If you have this system, I'd make sure the wiring is ok and hasn't been damaged bear the connection. They can and do wear out though over time.
Owned
Clio sport
Standard clio
Subaru legacy
Subaru Impreza WRX
Alfa Romeo 147
3 Ford's
2 Vauxhall's
Mgf
Peugeot 208
Re: Citroen P0121
Awesome thank you for that the vin is VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Citroen P0121
Hi, yes your accelerator has the throttle position sensors in the pedal on this model.
Owned
Clio sport
Standard clio
Subaru legacy
Subaru Impreza WRX
Alfa Romeo 147
3 Ford's
2 Vauxhall's
Mgf
Peugeot 208
Re: Citroen P0121
Hi
Thank you for this
Thank you for this
