DS4 heater blower
Yitearp
Re: DS4 heater blower
Unread post by Yitearp »
missed this - Great i will do so hopefully i can be pointed in the right direction to install also
cheers
x 6947
We can only offer you an official parts service, any technical help will be down to individuals to assist with. I should be able to pop up a guide in the donating members resources section for you though if you decide to go ahead.
Wayneh
Unread post by Wayneh »
Hi , I noticed this thread , I have same problem heater blower stopped working, took to local garage and they said motor and fuse is fine , there is no earth supply to motor . So was wondering where this earth connection is located and can try rectifying myself
x 6947
You may likely find it is the Heater Motor Control Module. When these fail it's usually all or nothing on the fan speed.
The power is supplied to the motor via the HMCM resistors, so that's why there won't be any power to the motor if this module has failed.
