Complained to the dealership general manager and they said it is because the tank they replaced is defective. All sounds very strange that they shipped the old part straight to Citroen, hopefully it will be replaced and fix this time...Rhothgar wrote: 25 Apr 2022, 15:18 Cool. Let us know how you get on. The key thing is to remain reasonable and respectful at all times so far as is possible.
“Firm but fair!” as an old boss of mine used to say.
HELPPPPP, Dealer just want money money money money
yingxue2022
- x 3
Re: HELPPPPP, Dealer just want money money money money
Onlinemyglaren
- x 5671
It all sounds quite suspicious.
Rhothgar
- (Donor 2026)
- x 221
It is very possible that a new part is faulty but it is VERY rare.
When I have issues or have things that think could become an issue. I make file notes like a solicitor would with dates, times and screenshots of phone calls and/or phone log just in case.
It is always good to write down the facts immediately just in case they are needed for future reference.
- x 6956
I'm thinking it is more than the tank - possibly the Urea injector or supply to / from the tank that may be the cause. We know that the NOx sensors can need replacing, but I would of hoped they would of checked that.
yingxue2022
- x 3
is that something major? how much will it cost to fix it? I have checked with Citroen and they now say it is possible to get an extended warranty (up to 100000miles), is it worth for me to keep the van or maybe like the garage people say just get rid of it? it is done 26k miles not even 3 years old... and new vans are also exteremly expensiveGiveMeABreak wrote: 27 Apr 2022, 10:47 I'm thinking it is more than the tank - possibly the Urea injector or supply to / from the tank that may be the cause. We know that the NOx sensors can need replacing, but I would of hoped they would of checked that.
yingxue2022
- x 3
Yes I did but I doubt it will be much of use... they know that sometimes we dont have that much time to deal with the issue, the service advicer at the branch seems really nice person and told me just to get rid of it. I think he meant to give me a good advise, but somehow I still feel that shouldnt be something coming out from them. i dont know cars let along vans.... headaches, just hope a new tank might solve the problem but I still have doubts. Dont trust them any moreRhothgar wrote: 27 Apr 2022, 10:01 It is very possible that a new part is faulty but it is VERY rare.
- x 6956
You have made some progress in now being offered a further extended warranty. Now you just need to get the current problem fixed from the last repair. Stick with it, stand your ground and don't be put off.
An extended warranty is worth it in my opinion, when you consider the cost of an Adblue tank at nearly a £1000 alone, so I would recommend it if you can once you get this issue sorted and if you are then happy with the van once fixed and your existing warranty expires.
yingxue2022
- x 3
what about NOx sensor, is it expensive to fix?GiveMeABreak wrote: 27 Apr 2022, 16:47 You have made some progress in now being offered a further extended warranty. Now you just need to get the current problem fixed from the last repair. Stick with it, stand your ground and don't be put off.
- x 6956
Well the part alone can be around £250 to £350 depending on model.
- x 1056
Not really strange, many high value parts need pre authorisation from PSA before fitting. The return request could have been submitted before they even fitted the new one.yingxue2022 wrote: 27 Apr 2022, 09:24 All sounds very strange that they shipped the old part straight to Citroen
The new tank could be faulty, PSA are still having issues with adblue systems to this day so its not to say the new tanks are much better.
Theres also a good chance the fault could have been misdiagnosed in the first place & the tank wasn’t the actual problem.
I really don’t believe they never replaced the tank if they told you they did. If they were caught doing this they can get a massive fine off PSA or potentially loose the franchise. They would also draw loads of attention from PSA for a warranty audit that can easily end up costing them 10’s of thousands of pounds.
yingxue2022
- x 3
sigh...so what exactly do I do? does this mean I should really just get rid of the van and find another vechile that doesnt require Ad blue / hiybrid or electrical?
This is frustrating...
Reason: Removed repeated Quotes
- x 6956
Most diesel vans a few years old will all have similar systems to meet the Euro standards, so that's really not going to solve your issue.
I suggested you stick with the dealer who repaired the tank and if they won't look at it again, contact Citroen Headquarters and escalate the issue.
yingxue2022
- x 3
yes that was also another concern, I am worried that I might have ad blue signal problem with other vans too... The dealership told Citroen that a new tank is needed again,and that was it. I have requested full diagnose report, and asked if Citroen can refer me to another dealership who is better with ad blue problem. This garage is strange from day 1, they checked the ad blue and told me that a new tank is needed etc. However they simply put down customer require new tank to be changed in the report.
- x 6956
I think you need to wait until Citroen respond - it seems you are now waiting for a response. Keep ringing up Head Office until you get a resolution. Tell them you are without a vehicle or can't use it reliably (whatever the case is) until the issue is resolved.
- x 1056
Most of the big manufacturers have problematic adblue system's. Ford are no better and the VAG & JLR systems are awful.yingxue2022 wrote: 28 Apr 2022, 17:05 sigh...so what exactly do I do? does this mean I should really just get rid of the van and find another vechile that doesnt require Ad blue / hiybrid or electrical?
This is frustrating...![]()
The dealer Diagbox diagnostic system saves diagnostic traces & PSA can check these to see what tests were done, when & how long it was connected etc. Another reason why I dont believe they would lie about the tank replacement. They will likely look at the traces to authorise a second tank.
