C4 Grand Picasso 2017 replace top BW screen
patriot35
Unread post by patriot35 »
Hi
Is it possible to replace instrument cluster display, which is black&white with a new widescreen hd color screen?
x 6950
Re: C4 Grand Picasso 2017 replace top BW screen
I suspect not as the colour displays will only be part of a different system and trim level - so you probably won't have the necessary electrical connections and other equipment / configuration / compatible instrument panel ECU.
