Citroen C4 VTS 2.0 16V - Oil leak from the crankshaft seal
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have an oil leak from the crankshaft oil seal ( the one at the flywheel side ). Oil seal part number is 012728. The seal has been replaced twice ( with genuine one ) but the oil continues to leak . Any idea what can cause this ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1061
Re: Citroen C4 VTS 2.0 16V - Oil leak from the crankshaft seal
Unread post by wheeler »
Are you using the correct fitting tool? I can only think it may be getting damaged on fitting if not using the correct mandrel to fit it, is it the older type radial lip seal with the spring in the back or the newer ptfe type seals? These normally come with the fitting tool.
