Ohfishalee
- x 7
Re: Citroen and Peugeot Official Parts Requests
Hello. I'm looking for part numbers for rear shocks, fuel lines and fuel filter housing.
My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
Peugeot Partner 2006
Shocks
Filter housing/fuel lines
Shocks
- x 6945
Rear Shocks
Rear Shock Absorbers (Original Part no longer available - these have been replaced with substitute shocks part: 9811401780, £88.70 each
Peugeot Cheaper Alternative rear Shock, part: 1623313380, £42.43 each
Fuel Filter
OEM Filter Cartridge Kit: part: 1906A9, £36.56
Alternative part: E148119, £6.17
Fuel Pipes As for the pipes, you'll need to let me know the item number of the relevant pipes on the above chart.
Fuel Filter
Ohfishalee
- x 7
Jay-Bruce
- x 280
Are the green o-rings on LDS pipes available separately? And if they are can I get parts number and price please?
- x 6945
OK, so the housing is (1) and includes A, (3) & (6), part: 191144, £163.64Ohfishalee wrote: 04 Apr 2022, 03:25![]()
Thank you very much!!
The Filter Housing (ref A) part number is what I am after, not the filter itself.
The pipes are ref C & D
Pipes
Item (16) is the correct one for your vehicle and this is a complete set of pipes, (A, B, C & D) as shown. They are not available separately. Part: 1574L3, £97.25
All VAT inclusive direct from Peugeot as of today.
- x 6945
The O-rings are not listed as separate parts for suspension components except for suspension cylinders Jay.Jay-Bruce wrote: 04 Apr 2022, 10:54 Are the green o-rings on LDS pipes available separately? And if they are can I get parts number and price please?
I ordered my O rings from here, after recommendation from Stu (Sloppysod) when my third steering rack was being fitted. They do all sorts of sizes and materials.
https://o-ring.info/en/materials/vitonr--fkm/
- x 5672
Wish I had seen that ^ a few days ago, my son was trying to get an O-ring for his motorbike and had a struggle, had to order one.
There is an Eriks only four miles from me that I have used a lot in the past but never for o-rings and never thought of them.
Ohfishalee
- x 7
Thanks much!!!GiveMeABreak wrote: 04 Apr 2022, 11:53OK, so the housing is (1) and includes A, (3) & (6), part: 191144, £163.64Ohfishalee wrote: 04 Apr 2022, 03:25![]()
Pipes
P/N for Fuel Injection pump is next on my list for same vehicle
- x 6945
@ Ohfishalee:
Sitting comfortably?
New OEM Fuel Injection Pump (1), Part: 1920AT, £4,148.63
Peugeot Exchange Injection Pump, Part: 1921F9, £1,998.20
Probably cheaper to buy a new van!
Ohfishalee
- x 7
Is the pump the same as in the DW8 engine?
- x 6945
No, the DW8B has electronic management and there are sensors / electronics on the pump where the DW8 doesn't, so wouldn't be compatible.
Ohfishalee
- x 7
Cheers!GiveMeABreak wrote: 06 Apr 2022, 09:29 No, the DW8B has electronic management and there are sensors / electronics on the pump where the DW8 doesn't, so wouldn't be compatible.
tizdaz
- x 4
Hi there, looking for part number for the NS front Splashguard for C4 Grand Picasso 2014 1.6eHDI:
cheers!
cheers!
- x 1493
Item 10?
£120.44 inc VAT, oddly the RH one is £25 cheaper....
tizdaz
- x 4
thanks buddy!
yeh a bit strange how one is cheaper!? it says RH has no grill, maybe cheaper because of that?
