Got two questions, if anyone kindly helps me through
It’s about couple of months there is some fluid spillage around the head gasket of my Xantia 1.9 TD. It’s a black oily liquid, but I’m not sure if its engine oil as the oil level has not changed over the time. It was OK before, but I think the problem might have raised cause of lots of high-speed motorway driving (90-100 mph, and the highest speed this car has gone hardly reaches to 110 mph). The car has also started puffing some large amount of white smoke on cold start, which disappears immediately.
Going through previous posts, I guessed maybe the head gasket needs replacement. I wanted to buy a new one, but it seems they are categorized on number and formation of notches. Is the gasket the reason of my problem? And how should I know which gasket should I buy before starting the job?
Second question is about MPG. The car seems to burn about 37-39 MPG. However the actual amount is worse and maybe about 30-35, as I think there might be some problem with its calibration. I know this as my GPS shows e.g. 70 mph while the speedo shows about 82-83 mph! What are the main reasons of high MPG for these cars? I’ve recently changed oil and all filters, and used some engine and injector cleaning fluids. No improve though!
Many thanks in advance,
Sahand.
