Many thanks MarcGiveMeABreak wrote: 18 Mar 2022, 13:05 Simon:
Item (1) New OEM ABS Hydraulic Block, Part: 4541S8, £1006.64
Item (1) Exchange ABS Hydraulic Block, Part: 1682608980, £979.43
Item (2) New OEM ABS ECU, Part: 4542Z3, £758.22
207Peugeot14
- (Donor 2021)
Re: Citroen and Peugeot Official Parts Requests
Rhothgar
- (Donor 2026)
- x 222
Could I have fiche for strut mounts for X435 JGJ please?
Before I strip and send existing ones to UAB Elastomer in Lithuania, I may as well check to see if Citroen have them available. My understanding is S2 are still available or were…
Surprised I made it to MOT!
It might be time to scrap the S2 HDi
- x 6948
@ Rhothgar: PM Sent.
Orchid70
- (Donor 2021)
- x 6
Hi Marc!
The plastic pipe between engine radiator and expansion buttle - is broken and someone has tried to glue it.... That exlanes why its been consuming coolant, Ive but in the normal 1 dl every 2-3 months but the owner has but in 5 liter the last 2 weeks....
Is the part number 1323A2 correrct?
To me it looks more like 1323Y4 though, if I look at pictures.
We are in Sweden.
Original pipe says: 4c001960
We are in Sweden.
- x 1056
Just want to check, that VIN is for a C4 picasso but you profile says you have a C5?
Part no: 1323Y4
This part is £13.18 + tax in the UK
Part no: 1323Y4
Orchid70
- (Donor 2021)
- x 6
I own C5.wheeler wrote: 22 Mar 2022, 20:27 Just want to check, that VIN is for a C4 picasso but you profile says you have a C5?
The C4 Grand Picasso is a customer car.
Thank you Wheeler!
- x 8151
Could I have the part number for my fleet C4 picasso vin VF7**************[VIN obfuscated, can be read by forum staff]. Throttle pedal please? Cheers
- x 6948
Hi Mick
Part: 1601EE, £206.36 inc VAT
- x 8151
Thanks Marc!!
Remithevan
If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
- x 1056
The VIN will give you The Citroen part number but i suspect the repair people are after the manufacturers part number which is normally on the actual part itself either embossed on the plastic or on a sticker. The part number on the unit will not be the same as the dealer part number.Remithevan wrote: 25 Mar 2022, 17:28 If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
Remithevan
This is turning out to be a pain, guessing they can only reapir certain brands of BSi unit.wheeler wrote: 25 Mar 2022, 18:40The VIN will give you The Citroen part number but i suspect the repair people are after the manufacturers part number which is normally on the actual part itself either embossed on the plastic or on a sticker. The part number on the unit will not be the same as the dealer part number.Remithevan wrote: 25 Mar 2022, 17:28 If I donate, isnit possible to find the part number for my berlingo vans BSI as it would appear there is no sticker on the unit?
Make see how much stealers want to replace it.. really just need it sorted.
- x 1056
An exchange BSI from Citroen is around £260 (new on is around £440) just for the part and at a guess they would want at least 1.5 hours labour for fitting & programming.
207Peugeot14
- (Donor 2021)
Peugeot 207 1.4 hdi 2011
Scuttle panel please Marc
Thanks simon
Thanks simon
- x 1056
