Huskyxantia
- x 925
Re: Citroen and Peugeot Official Parts Requests
Would it be possible to have a part number for this item and if possible a diagram of how it goes to the fuel tank also the part i have highlighted is that a breather of some sort ?
Many thanks.
Many thanks.
Husky.
- x 6946
Mick, that VIN is incorrect (18, when it should be 17) and also, can you confirm you want the pulley for the accessory belt?mickthemaverick wrote: 15 Mar 2022, 12:54 Hi Marc,
Peugeot 406 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could I have the part no for the harmonic balancing pully please
Cheers
- x 6946
That is the fuel filler pipe and yes that is the breather.Huskyxantia wrote: 15 Mar 2022, 22:26 Marc
Many thanks.
Item (1) Part: 1503T5, no longer available.
- x 8146
Sorry Marc, I copied the vin from the screen in bright sun straight onto the phone and possibly had big finger slip! I got the model wrong, it is a 206 not a 406 - post covid brain fade -. Hopefully that explains the VIN issue? Yes it is the crankshaft rubber mounted pulley at the bottom of the accessory belt run. ThanksGiveMeABreak wrote: 16 Mar 2022, 00:14Mick, that VIN is incorrect (18, when it should be 17) and also, can you confirm you want the pulley for the accessory belt?mickthemaverick wrote: 15 Mar 2022, 12:54 Hi Marc,
Peugeot 406 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Cheers
Huskyxantia
- x 925
Thank you Marc, top man .
Husky.
- x 6946
That's not helping Mick - the VIN you edited in the previous page is still incorrect. Also, please note that you can't quote an obfuscated VIN in a new post as the VIN has already been converted to asterisks, so I can't read it. Please always retype the VIN in full. Once I have this I will save it for future requests for you.mickthemaverick wrote: 16 Mar 2022, 02:01 Sorry Marc, I copied the vin from the screen in bright sun straight onto the phone and possibly had big finger slip! I got the model wrong, it is a 206 not a 406 - post covid brain fade -. Hopefully that explains the VIN issue? Yes it is the crankshaft rubber mounted pulley at the bottom of the accessory belt run. Thanks
- x 8146
Is this ok for 206 HDi
I cannot get back to the car to confirm it as it is 35 miles away!!
Sorry for this hassle
Cheers
Mick
Cheers
Mick
Huskyxantia
- x 925
Hi Marc,
Needing some part numbers for a drive shaft for my
206cc 1.6hdi 06 reg offside front. Also what length ? Im seeing 2 different sizes for some reason.
Many thanks
Many thanks
Husky.
- x 6946
Still a no go, if I use the last 8 digits it comes up as a 206 3 DOOR SALOON 1.1 i (TU1JP) Manual gearbox 5. The beginning of the VIN is totally different, V_F_3_2_C_H_F_X_Fmickthemaverick wrote: 16 Mar 2022, 16:23 Is this ok for 206 HDi
Cheers
Mick
If this is the one let me know.
- x 6946
The Left and Right Driveshafts are different lengths. I've provided part numbers for both for future reference.Huskyxantia wrote: 17 Mar 2022, 08:13 Hi Marc,
Many thanks
Item (2) Right Drive Shaft OEM, (MARKING 8LN18 8LN15 (8LN18)), Part: 32730Y, £401.40
Item (2) Right Drive Shaft Exchange, Part: 32730Z, £234.07
Item (1) Left Drive Shaft OEM (MARKING 8MN34), Part: 3272EZ, £401.40
No Exchange alternative for the left DS.
Note all the above have a refundable £66.96 deposit when the old one is returned.
- x 8146
Thanks for your time on this, there is clearly a problem with the car's ID, so I have told the owner to source the new pulley from their dealer and then I'll go and refit it if necessary!! Thanks again
- x 6946
I think there are too many ‘H’s in the VIN Mick.
Huskyxantia
- x 925
Husky.
207Peugeot14
- (Donor 2021)
ABS ecu unit please, and ABS module
Separate parts please marc
Many thanks Simon
Many thanks Simon
- x 6946
Simon:
Item (1) New OEM ABS Hydraulic Block, Part: 4541S8, £1006.64
Item (1) Exchange ABS Hydraulic Block, Part: 1682608980, £979.43
Item (2) New OEM ABS ECU, Part: 4542Z3, £758.22
