aljo221
- (Donor 2021)
P508 Window mechanism
Hello, can someone help me please.
I would need the part number for the front left window lift mechanism (left hand drive).
VIN number is VF3**************[VIN obfuscated, can be read by forum staff]
Thanks, Igor
Thanks, Igor
- x 6945
Re: Citroen and Peugeot Official Parts Requests
Here you go:
Item (3) Left Side
OEM Original Part: 9806086980, £448.00
PSA Cheaper Alternative Part: 1619991780, £150.89
Note, the OEM original includes the electric motor, whilst the cheaper alternative does not contain the motor.
All available direct from Peugeot inc. UK VAT@ 20%
Item (3) Left Side
aljo221
- (Donor 2021)
Thanks Marc
207Peugeot14
- (Donor 2021)
Re: Citroen and Peugeot Parts Requests
Thanks MarcGiveMeABreak wrote: 12 Feb 2022, 10:40 @207Peugeot14: Here you go. The DPF element is separate and as you can see from the diagram is clamped on with the kit item (19), which I have included in case you need one of these in case it is rusted.
Particle Filter, item (11):
OEM Original Part: 9677468180 £913.06
OEM Alternative Exchange Part: 1606857180 £619.40
Exhaust Kit for DPF, Part: 1606644780, £68.48
All direct from Peugeot including VAT, prices as of today.
Any ideas of the part number for the pipe that's just past the dpf and goes to the differential pressure sensor please, item 17 in the diagram i think please, the end of mine has come off..
Many thanks Simon
- x 6945
(16) is the inlet particle filter pressure pipe, part: 1714P1, £27.97
(17) is the outlet particle filter pressure pipe, part: 1714P2, £30.10
207Peugeot14
- (Donor 2021)
Perfect Marc
Many thanks ordered
Many thanks ordered
Huskyxantia
- x 915
Crankshaft position sensor for xsara picasso 2.0hdi,
Also whats the purpose of the camshaft sensor & crankshaft sensor, ? And part numbers and locations of both .
Thanks mark
Thanks mark
Husky.
- x 6945
The crankshaft sensor detets the position of the crankshaft and the TDC (Top Dead Centre) of the piston, and lets the engine ECU know, so that it can determine injection and also the RPM. It's also referred to as the engine Speed Sensor.
The Camshaft sensor determines the position of the Camshaft when running and is similar.
(6) Engine Speed Sensor (Crankshaft Sensor) Part: 1920EN, £27.95
(15) Camshaft Position Sensor Part: 1920QN, £50.33
Huskyxantia
- x 915
Many thanks Marc.
Husky.
Huskyxantia
- x 915
Back again , needing front strut , spring & top mount for my 206cc 1.6hdi 06 model allure, my top mount has decided to get noise yesterday number and diagram would be very appreciated
Thanks Marc.
Thanks Marc.
Husky.
- x 6945
Ok, so the front shocks have alternative parts now and as you know must be replaced in pairs.
Struts (1) OEM Strut, parts, left and right:
9810758580, £87.18
9810758680, £87.18
Cheaper PSA alternatives parts:
1674698080, £53.11
1674698180, £53.11
Item (3) Strut Rod Protector, part: 525430, £6.47
Springs OEM (1) Front Spring (1 Yellow +2 Red), part: 5005X4, £149.80 (each)
(2) Front Rest Cup, part: 503184, £37.14
(4) 503360 Front Suspension Bump Stop, part: 503360, £24.32
(6) Shock Absorber Bracket Left, part: 5038C5, £60.43
(6) Shock Absorber Bracket Right, part: 5038C6, £60.43
(9) OEM Shock Mounting kit Left, part: 5031A2, £53.48
(9) OEM Shock Mounting kit Right, part: 5031A1, £53.48
(9) Cheaper Shock Mounting kit Left, part: 1638381480, £49.70
(9) Cheaper Shock Mounting kit Right, part: 1638381580, £49.70
9810758580, £87.18
9810758680, £87.18
1674698080, £53.11
1674698180, £53.11
Huskyxantia
- x 915
Thank you so much this is brilliant .
Husky.
osx
- x 15
Missing EGR mounting bolt
Replaced the EGR today but when I removed the old one there was only one bolt holding it in place (which was also loose). What type is it - does it have to be a PSA specific one or will any aftermarket 6cm bolt do the job?
Reason: Moved to Official Parts Thread
C5 X7 Exclusive 2.0 HDi Auto
- x 6945
I've highlighted the obvious looking bolts if these are what you need - click the image to zoom:
(8) MUL Flanged Screw Diam 6 x 100-60, Part: 101116, £2.15
(9) MUL Flanged Screw Diam 6 x 100-20, Part: 025057, £1.96
If anything else, let me have the item number form the above diagram.
- x 8124
Hi Marc,
Peugeot 406 HDI
Vin VF3**************[VIN obfuscated, can be read by forum staff]
Could I have the part no for the harmonic balancing pully please
Cheers
Peugeot 406 HDI
Cheers
