Additive low
x 6961
Re: Additive low
c4GPicasso wrote: 18 Feb 2021, 16:48 I managed to top up the additive tank ( very messy ) as the bottle didnt come with a refill kit. I have tried numerous times to reset the counter but the warning still shows up ( im using LEXIA ). Is there a walk through guide? is there a pump to prime first etc? Communication error with the additive ECU pops up on a global test, could this be the issue?
There shouldn't be a separate additive ECU on a C4 Picasso of this year. It should be handled by the engine ECU. That may be why it is nit communicating with it as there isn't one.
After the Global Test, go onto the Engine ECU, select that and look into the following menus, (Repair / Pack Repair) or may be something else and look for the relevant option around there.
With Mick’s MK I C5 these did have a separate additive ECU and they commonly failed on the early models when trying to reset them, often requiring replacements.
So have another look and let us know how you get on.
admiral51
(Donor 2026)
x 394
Re: Additive low
Unread post by admiral51 »
Joe i had similar issues when trying to reset my 2010 C5 X7 additive level and service light.
I eventually managed to find a way more by luck than judgement.
After the Global Test look for the Ignition/Injection ECU and then go to the repair section for the additive, cannot remember exactly what it was called but i found it by trial and error
I found the following 3 options
1.Refill additive tank.
2.Replace additive tank/replace additive pipework
3.Replace DPF filter.
I did #1 first and followed the on screen prompts.
I then did #2 as i assumed this would tell the system that it needs to prime itself
May not be the same on yours but as we know Citroen do things there own way.
Colin
c4GPicasso
(Donor 2021)
Re: Additive low
Unread post by c4GPicasso »
admiral51 wrote: 19 Feb 2021, 16:06 Joe i had similar issues when trying to reset my 2010 C5 X7 additive level and service light.
Colin
Finally got it reset. As suggested I ran a global test then clicked on the engine ECU. I clicked on 1.Refill additive tank.
2.Replace additive tank/replace additive pipework.
Thanks for the info all
admiral51
(Donor 2026)
x 394
Re: Additive low
:beer: Well done for getting it sorted :beer:
Kenmof
Re: Additive low
Unread post by Kenmof »
Just got this on last night on my 3008, anyone local to Glasgow that might be able to help, 🥲
x 6961
Re: Additive low
Basically you need to get the diesel additive fluid tank topped up. The Engine ECU will also need resetting when this has been done. So the dealer or a competent mechanic who has experience with this if you don't want to buy the fluid, filling kit or have a diagnostic toolkit to do this yourself.
Kenmof
Re: Additive low
Dont have an issue doing it myself, im confident enough with spanner's etc any idea where i would find out which fluid it is to suit my one, believe theres a few different options
x 6961
Re: Additive low
We'll need your VIN, pop it up here (automasked on post submission). If you don't have a dealer-level diagnostic tool, see below for others who may be able to assist:
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
Kenmof
Re: Additive low
Brilliant thanks, ive messaged someone on here to see if they can assist, vin VF3**************[VIN obfuscated, can be read by forum staff]
x 6961
Re: Additive low
Ok, so for that build date you need Eolys Powerflex Blue and you have a reservoir not a pouch system.
Kenmof
Re: Additive low
Thanks marc,, ill have a look
