Fuel Prices
x 1240
Re: Fuel Prices
Unread post by Peter.N. »
Its Paraffin.
x 8126
Re: Fuel Prices
Filled up with my E5 at my local Shell station this morning - £1.78.9 ppl !! :cry:
I fear the £100.00 tank is just around the corner!!
x 1240
Re: Fuel Prices
Heating oil nearly £1.50 today but should be going down - apparently
Peter.
x 6945
Re: Fuel Prices
£1.89 for diesel yesterday here.
This is where the Connected Live Services kick in for those with Connected Nav systems, as it shows the fuel station prices - so useful for those in larger towns and cities. This helped yesterday as on the way to the dentist the gulf station was showing as £1.69, but Tesco was still at £1.54, so topped up there!
They need to cut the fuel duty immediately and significantly otherwise the country will soon come to a standstill at this rate.
x 5672
Re: Fuel Prices
I saw that the output from (IIRC) Saudi was being increased to offset the Russian problem which should reduce prices.
x 1240
Re: Fuel Prices
Judging by the amount of traffic down here today it seems that few people are bothered about the price.
Went into Tesco Axminster yesterday and they didn't have any diesel.
x 7165
Re: Fuel Prices
They are getting hot under the collar down at Penryn in today's FCF "County in the spotlight"
viewtopic.php?p=711624#p711624
x 6945
Re: Fuel Prices
x 8126
Re: Fuel Prices
Typical!!! I knew about the likely change to fuel duty today but forgot and went and filled up at 1.81.9/litre. 43.24 litres cost me £78.65. Had I left it till tonight I could have saved £2.16 !!! Not even enough for a pint so I can't really say I'm that bothered. Plus of course by filling this morning I avoided a day of EV style range anxiety!! :-D
x 5672
Re: Fuel Prices
I filled up on Monday, superunleaded @ 175.9p per Litre.
x 1240
Re: Fuel Prices
Heating oil gone down by about 50p this week from £1.60 to 1.10 p.
x 6945
Re: Fuel Prices
It was about 52p a litre about 5 months ago here.
Armidillo
(Donor 2022)
x 274
Re: Fuel Prices
Unread post by Armidillo »
Peter.N. wrote: 24 Mar 2022, 00:05 Heating oil gone down by about 50p this week from £1.60 to 1.10 p.
Can you use it as fuel in a diesel engine?
x 6945
Re: Fuel Prices
Kerosene is a lighter oil and has none of the additives used in diesel, so does not have the required lubricants. Using this will likely cause fuel component failure, including fuel pump, seals and gaskets as examples.
x 3565
Re: Fuel Prices
Older diesels will run on various 'heating oils' with varying success. The main issue is that you can't get caught using non DERV fuel in most road-going vehicles with only a very limited number of exceptions........
