cs101
- x 6
Re: Citroen and Peugeot Parts Requests
https://www.ebay.co.uk/itm/GENUINE-PEUG ... 635-2958-0
Is this the right item to purchase from EBay? Thanks .
- x 6945
Yes, that cross references with the part number I gave you if you scroll down to the details.
Orchid70
- (Donor 2021)
- x 6
Hi Marc
I have three fault codes for parking sensors rear and front.
Is the sensor same in all positions for VIN VF7**************[VIN obfuscated, can be read by forum staff]?
Also - I gave fault code 4AC5 - short to plus on the third brake light.
- x 6945
Hi, yes they are all the same. The only difference is whether you want the black plastic (un-primed) or the primed versions, but same for front and back.
Black, Part: 1611735580 £140.95 each.
Primed Ready for Painting, Part: 1611735680, £140.81 each.
Prices UK sterling inc. our VAT @ 20%
quintet
- x 44
Hi Marc, could you please get me the part number for the little bolt that holds the nearside rear abs sensor in place. I have a suspicion it might only come with the sensor but with the bolt being seized in it might be as well for me to get a sensor as well.
VF3**************[VIN obfuscated, can be read by forum staff] & has Lucas brakes on it.
Thank you.
Thank you.
Music keeps me going.
- x 6945
Sure, here you go:
If it's item (70), then it is an (MUL) CHC R D L SCREW, part: 6913J1 (DIAM 6X100-20), priced £1.90 each from Citroen / Peugeot
quintet
- x 44
Great, thank you Marc, it is item number 70 i'm after, i'll contact PSA and order one (might replace the osr one too).
Huskyxantia
- x 909
Hi Marc
Time to sort the front brakes on the xsara picasso.
Part numbers needed for front brake discs & pads for my picasso 03 2.0hdi might As well have there rear shoes plus brake drums too while I'm asking.Thanks in advance.
Husky.
- x 6945
Ok, here you go:
Front Brakes
Discs (1)
OEM Original, Part: 4249G1, £151.51 (pair)
OEM Cheaper, Part: 1618890480, £58.42 (pair)
Pads
OEM Original, Part: 425475, £81.86
OEM Cheaper, Part: 1617282980, £26.21
Shim Set
Part: 440719, £23.29
Rear Brakes
You have the following options:
OEM Drum only, Part: 424724, £190.73
OEM Shoes Only, Part: 1610091280, £108.28
or
A complete shoe mounting kit (4) that includes shoes and cylinders and the bits as identified:
OEM Part: 1610091380, £215.38
OEN Cheaper Kit Part: E170042, £66.50
Front Brakes
Discs (1)
Pads
Shim Set
Rear Brakes
or
Huskyxantia
- x 909
Thanks Marc , im all sorted now , thank you.
Husky.
KennyW
- x 165
Marc,
Looking for part no’s for rear discs and pads for my C5x7
Vin no VF7**************[VIN obfuscated, can be read by forum staff]
Kenny
Kenny
C3 1.4 petrol (SWMBO)
- x 6945
Here you go Kenny:
(1) OEM Genuine Disks Kit Pro, part: 4549C1, £109.25
OEM Cheaper Alternative, part: 1618861880, £59.00
(2) OEM Pads, Part: 425405, £92.10
KennyW
- x 165
Thanks Marc
207Peugeot14
- (Donor 2021)
Hi Marc
After part numbers for the DPF please, also wondered if just the bottom of mine comes off or is it a complete unit as one.
Diesel particular filter for 207 1.4 hdi please
- x 6945
@207Peugeot14: Here you go. The DPF element is separate and as you can see from the diagram is clamped on with the kit item (19), which I have included in case you need one of these in case it is rusted.
Particle Filter, item (11):
OEM Original Part: 9677468180 £913.06
OEM Alternative Exchange Part: 1606857180 £619.40
Exhaust Kit for DPF, Part: 1606644780, £68.48
All direct from Peugeot including VAT, prices as of today.
