C5 X7 front bushing
davoxx
x 15
C5 X7 front bushing
Unread post by davoxx »
https://images.ilcats.ru/getImage.php?c ... 4b3d8ad926
I'm looking for the bushing at the end of the suspension strut. It doesn't have a part no in the pic.
I'm sure Dealer prices are mad.
It looks like a hand job -
but how do you tighten the bolts with the suspension at normal height? Would having the front of the car on ramps work?
Also where can I get the shaft sleeve for a leaking steering rack? I saw it in a post here, but could not see if they got it or if it worked.
I'll change the rack once I stop being unemployed.
why?
davoxx
x 15
Re: C5 X7 front bushing
Is this the correct OEM no - 365604
https://www.ebay.co.uk/itm/332528502120
that's quite cheap.
Or would https://silentblocks.com/index.php?id_p ... &id_lang=1) be better, one time job?
why?
davoxx
x 15
is 7832501318 the correct part no for my steering rack
why?
aerodynamica
x 215
Unread post by aerodynamica »
davoxx wrote: 28 Jan 2022, 15:39 Is this the correct OEM no - 365604
that's quite cheap.
I think the first one here is correct - I just changed mine. I got them from AEP parts and they're Meyle brand which i think are considered decent but of course, time will tell....
Graeme M
davoxx
x 15
I need to change mine again, and want to get better quality ones.
I have an estate and it's often loaded so it's not surprising that they failed.
Who makes the oem ones? Or which a good branded ones to use?
why?
