2015 Citroen C4 B7 Diagnostics
DHallworth
- x 161
Evening all,
The wifes C4 has started moaning about an ABS/ESR fault and the hill assist feature has stopped working. It started as intermittent and would do it once every now and again but this week it’s become permanent.
Unfortunately my version of Diagbox doesn’t like talking to the C4. Is there a newer version that will run on the clone hardware and allow me to read the codes?
Thanks,
David.
Thanks,
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6946
Re: 2015 Citroen C4 B7 Diagnostics
What version of DB are you running David? You may just be on the cusp of reading it with a late V7.** version of the software.
DHallworth
- x 161
According to the digits on the top right hand side of the screen, I’m running V07.15.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6946
Have a look at the change logs I put up one the Wiki David - some of the later versions 7.6* go up to 2015:
https://frenchcarforum.co.uk/wiki/Diagb ... 9/7.06_On)
DHallworth
- x 161
Thanks Marc,
My interface is a very early one so am wondering if it’ll support the upgrade. Is there a reliable source of download these days? I need to go up incrementally rather then going straight to 7.6x too, don’t I?
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 3296
Marc has a version checker that can let you know what version of the hardware you have. I have an Easy Diagnostics vB unit, and it will accept DiagBox V7.15, but not anything over that.
- x 6946
If it's an older revision B David, then yes you're probably stuck at the lower DB 7 version. I have the updates, but not advised if you think it's too early.DHallworth wrote: 20 Jan 2022, 21:20 Thanks Marc,
DHallworth
- x 161
I think it probably is. I think I’ve had it since 2008ish.
I’ll pop to see a friend who has a Snap On machine with the C4 and get him to plug it in for me I think. Much less hassle
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
- x 161
Just been and had a fiddle…
Version 7,15 will talk to the C4, however, the only 2 ECU’s it talks to are the ABS and the Module under the steering wheel.
Thankfully, it was the ABS I needed access to and it’s told me it doesn’t like the rear right ABS sensor!
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6946
Good news on that front then!
DHallworth
- x 161
Indeed!
Even better - managed to get a brand new, genuine Citroen ABS sensor on eBay for under 18 quid!
Getting a C1335 fault code on it as soon as the engine is started and the code suggests a short circuit on the sensor so should be too bad to sort hopefully!
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6946
That usually tends to be dirt in the plug connection or a loose pin / socket, which is not unexpected considering the torture these go through. But £18 isn't bad either.
- x 1496
Is this the same as the MK2 Picasso, with the on caliper electric handbrake? In which case it could well be the wiring disintegrating rather than the actual sensor itself...
- x 6946
No, it uses a separate control unit Richard with cables operating the calipers, so no on-caliper motors like the latest C4 Picasso.
DHallworth
- x 161
Me again
I’ve bought a new Smeg IV2+ unit from eBay for the C4 to enable Apple Car Play.
I’ve managed to install it this evening, configured the VIN to stop the annoying been but I need to finish configuring it to get the buttons on the dashboard to work.
I think I’m going to need to upgrade my interface and Diagbox version as 7.15 won’t let me near it to configure it, it keeps failing.
Is there a reliable source for hardware these days?
Thanks,
David.
Thanks,
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
