New c5 owner build sheet for my car
Peugeot2003
Hi to all hope someone can help trying to get build sheet for my car as I have spar cable in boot behind passerger compartment and don't no what for thanks
- x 6955
Re: New c5 owner build sheet for my car
Don't worry about it. It may be for a trailer module or an option you do not have.
Peugeot2003
OK how do I find what's for as like try add what might be thanks
- x 6955
Why? If you don't have the options you more than likely can't retrofit as the harnesses on the C5 X7 are all different according to options specified at factory.
It's not easy just adding things as they often need to have additional hardware, wiring looms, programming of ECUs and the rest of it. If it is the wiring for a trailer fuse board, there's no point in buying this and adding it without the towbar and full electric kit as an example, which needs further wiring.
A photograph will help us identify the part anyway and post your VIN up too (automasked on post submission).
Peugeot2003
Hi this is plug I'm on about hope someone can tell what's for vehical vin VF7**************[VIN obfuscated, can be read by forum staff]
- x 3300
If you can see any numbers printed on the wires it would help to post them here. PSA don't always use consistent colour coding, but their numerical code is consistent.
