Citroën C1 1.0 Petrol 2008 - What oil type?
Nego2403
I have a Citroën C1 1.0 Petrol from 2008. The service booklet recommends that the oil used in the car should be a Total Quartz 5000 15W40 oil. Can this be correct? In my country it is sometimes -15 celcius degrees in the winter and the oil is only rated for -20 celcius degrees. Should I use the recommended oil or do you guys have other alternatives?
- x 6947
Re: Citroën C1 1.0 Petrol 2008 - What oil type?
Pop your VIN up so we know the exact engine, then we can check against this and the Country.
Nego2403
The VIN of the car is VF7**************[VIN obfuscated, can be read by forum staff].
- x 6947
Well of course this being a C1 is essentially a Toyota and uses the Toyota engine. So that oil recommendation is totally incorrect - it must be for another engine.
You have a CFA engine code, which is a 384F engine.
Denmark is listed as a Temperate / Cold country in group 'A' so if you have a look in the official PSA recommended oils section, (link below)
https://www.frenchcarforum.co.uk/forum/ ... hp?t=67630
You will see the following. Your vehicle can take any of the 4 oils mentioned.
TOYOTA Engines.
TOYOTA Engines.
| Engine Type | Engine Identification | 0W30 Oil B71 2312 | 5W30 Oil B71 2290 | 5W40 Oil B71 2296 | 10W40 Oil B71 2300 |
| 384F | CFA / CFB | OK | OK | OK | OK |
| 1KR-FE | CFB | - | OK | - | OK |
Nego2403
Thank you very much this is just what I needed! It says that I'm not authorized to read the link you've sent me
- x 6947
Ok, I put the relevant extract up for you - the section is for donating members, but it should give you all you need.
