My turn for a C5!
- x 3306
Re: My turn for a C5!
OK, it seems that there is an electro-valve gone open circuit, so that is the next thing to deal with.
Does anybody know if heated seats need to have anything enabled (such as in the BSi) for them to work? There is nothing happening re heating (no light on the control and no heat). It is not down to the fuses, as the maxi-fuse drives both the motors and the heaters, and the seats do move and the four lesser fuses are of the correct amperage and are fine.
citroenxm
- Fallen Hero
- x 70
They need 12v putting to the plugs under the carpets James.. The cables need adding from the small yellow fuse box above the bsi behind the glove box.
Aside of that I don't know if the seat elements work or not.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3306
Well, my C5 is certainly giving my Lexia a workout (and my poor wallet conniptions!). One of the actuators on the turbocharger has gone open circuit (the one that manages V2C). It is the one that manages the vanes. It does not appear to be an item that can be purchased from Citroen (they want you buy the whole turbocharger!), but the part I want is on 0375 P1, and (if you were to get the correct diagram open) appears to be directly indicated by the '1' line (according to the mechanic). Does anybody have access to the diagram for this turbocharger (with a parts list)? The RPO is pre 11100.
The diagram I am looking at has the number 0601 01 172019A.
Failing the turbo diagram could somebody post up the wiring diagram, so I can check for an open circuit? Can anybody let me know what voltage the actuator is driven by (I can connect up my digital multi meter using the 'hold' function to see if there is a signal getting to the actuator).
- x 3306
Can anybody help me with this?
- x 3306
Thanks, Mick. I have had a look on their website, and they don't seem to cover the C5 from 2007, but it was definitely worth checking out.mickthemaverick wrote: 15 Dec 2021, 12:46 James, while I had my 3 2.2s I downloaded the service manual from the link below. It didn't solve all the issues but it was helpful in clarifying where things were etc. You may find it useful:
https://hostpdf.com/citroen-c5-2-2-hdi- ... ir-manual/
- x 6957
Probably would of been better to create a new post James when needing specific info - with long threads like this (which is more or less a blog from the title) they may not be read. With hundreds of posts to scan we (staff) tend to prioritise responses based on the post title.
Leave it with me, now I have seen this.
- x 3306
Thanks, Marc.
- x 6957
Your Turbo, for which there are no internal parts listed separately James. This engine has 2 fixed geometry turbos, with the first low inertia kicking in at low engine speeds and the second turbo kicks in at 2700 RPM, so collectively covering the entire engine speed range.
0375P1 (new OEM) is £2341.39
An Exchange Turbo is £1987.40
Both the above have an additional refundable surcharge of £260.40 when the old turbo is returned should you go down this route.
Component
Wiring
Here are the Injection System Components:
As for the Proportional Electrovalve (VT2) control, you need to be checking on the 48 Pin GREY plug (CME) of the engine ECU as shown below. It is pin E4.
Wire 1446 goes from the VT2 electrovalve (1393) on Pin 2 to Pin E4 of the engine 48 pin Grey ECU CME Plug as noted above.
Here is the location of the electrovalves (1393 in your case):
Component
Wiring
| BSI1 | Built-in systems interface |
| 0004 | Instrument panel |
| 1115 | Cylinder reference sensor or camshaft sensor |
| 1158 | Pre-post heating control unit |
| 1160 | Pre-heater plugs |
| 1208 | Diesel fuel injection pump / Diesel fuel volumetric regulator |
| 1220 | engine coolant temperature sensor |
| 1221 | Fuel temperature sensor |
| 1240 | Air temperature sensor |
| 1261 | Accelerator pedal position sensor |
| 1283 | Additive injection pump |
| 1297 | Electric EGR electrovalve |
| 1310 | Air flow meter |
| 1312 | Inlet air pressure sensor |
| 1313 | Engine speed sensor |
| 1320 | Diesel injection ECU |
| 1321 | Diesel high pressure sensor |
| 1322 | Diesel high pressure regulator (DRV) |
| 1324 | Electric doser with position copy |
| 1331 | No. 1 cylinder injector |
| 1332 | No. 2 cylinder injector |
| 1333 | No. 3 cylinder injector |
| 1334 | No. 4 cylinder injector |
| 1341 | Particle filter differential pressure sensor |
| 1343 | Downstream exhaust gas high pressure and high temperature sensor |
| 1357 | Proportional oxygen sensor |
| 1374 | Turbo position copy sensor2 |
| 1390 | Inlet air pressure sensor |
| 1392 | Proportional electrovalve (Waste gate) (VT1) |
| 1393 | Proportional electrovalve (VT2) |
| 1396 | Turbine gas recycling electrovalve 2 (TOR) |
| 1397 | Compensation electrovalve (VC2) |
| 2120 | Brake twin function switch |
| 4050 | Sensor for presence of water in diesel fuel |
| 4100 | Oil level and temperature gauge |
| 7306 | Cruise control safety switch (brake) |
| 7316 | Vehicle speed limiter switch |
| 8009 | Linear pressure sensor for the air conditioning fluid |
- x 3306
Thanks, Marc, that is very useful. Which pins for the V2C control (as it is this that my Lexia is showing as open circuit)?
I knew the turbo was expensive, but that is scaring the cr4p out of my wallet!
- x 6957
For 1397 (Compensation Electrovalve), wire 1451 compressor valve 2 signal goes from Pin 2 on the electrovalve to pin H2 on the same wiring block - it's all on the main diagram.
- x 3306
Well, time for a bit of an update, She passed her MoT yesterday (with advisories, which I am now working on), so that is OK. With reference to the turbo issue I found that (on the vacuum control block (or whatever it is called)) the latch moulding for one cable had become deformed, so the latch on the cable plug does not hold it in place. By using a cable tie around the latch clip it is now staying in place. It is safe to say the turbocharger is now fully operative, as her performance has definitely got more spirited, especially when the Sports button has been pressed! Yay! (Oh, and my Lexia went from showing a permanent, unclearable fault to a temporary, clearable one (and running the tests again after it was cleared showed there were no faults found in the Injection section)). Without the diagram from Marc I would not have known where to start looking (as the turbocharger is on the back of the engine and the vacuum control block is on the front!).
- x 8100
Well done James, sounds like she is coming together nicely!
citroenxm
- Fallen Hero
- x 70
That's interesting. Have you got any pics James I know of another 2.2 hdi with a simmilar problem that may be the same thing.Hell Razor5543 wrote: 12 Jan 2022, 06:47 Well, time for a bit of an update, She passed her MoT yesterday (with advisories, which I am now working on), so that is OK. With reference to the turbo issue I found that (on the vacuum control block (or whatever it is called)) the latch moulding for one cable had become deformed, so the latch on the cable plug does not hold in place. By using a cable tie around the latch clip it is now staying in place. It is safe to say the turbocharger is now fully operative, as her performance has definitely got more spirited, especially when the Sports button has been pressed! Yay!
Glad you found that out.. They do go increadably well..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 3306
Paul, the vacuum control block is on the front right of the engine, hidden under the second air intake. The plug with the cable tie (behind the three silver pipes) is the one that controls the V2C compensator valve.
citroenxm
- Fallen Hero
- x 70
Wow. Well found.
As for seat belts.. Its a common c5 issue.. Pull the belts out fully.. Peg it to stop it retracting and then soak the belts in hot soapy water over night.. Get all the crap out of them then dry them. Spray some furniture polish on them and let them back in... Should sort them out do I beleve..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
