wesacosa
(Donor 2021)
x 3
Re: Citroen and Peugeot Parts Requests
Unread post by wesacosa »
Hi All
I was wondering if someone could please post the exploded diagram of the ABS ECU and the ABS block for a 1997 XM (Teves ABS) so I can see what fixings hold the ECU to the block
Wes
x 6948
@ Wes:
There are 2 versions and you could have either:- Bendix or Teves. Both are different as you can see. This is for your VIN ending 804.
Bendix AssemblyTeves Assembly
wesacosa
(Donor 2021)
x 3
Hi Marc. Thanks. I have the Teves so should be the one on the right. Seems its just two bolts and the wire plug to get it off the ABS block, but I wonder if the bracket (bolts 70 and 71) have to come out before it can be removed from the block
Wes
x 1476
Unread post by xantia_v6 »
My recollection is that there are bosses on the block which protrude into the electronics module (not shown on that diagram) , and these could be a tight fit, but I think that it is just the two screws to remove. I may be thinking of the later Teves Mk20 system fitted to later XMs.
wesacosa
(Donor 2021)
x 3
I did try and look at a photo of the back of the module ( I could only find a Xantia one) but I couldnt see any recesses where a boss may go, but perhaps the XM does. I suspect if its anything like the rest of the car it will be fiddly to get off :)
Huskyxantia
x 927
Unread post by Huskyxantia »
Hi marc,
Im thinking of doing the rear axle on my 206cc , would changing the bushes do or would it for the sake of speed and it having to come off , be best to get a refurbished one ?
If possible could i have an exploded view of the rear axle and all part numbers possible also the complete rear brake set up aswell , looks like spring will be busy time for me if i go either way with the rebuild.
Thanks again ..
:-D
Huskyxantia
x 927
Driveshafts for a 206cc 1.6hdi , would 1.6 petrol be ok ? Part numbers for ns please , cheers marc.
:-D
x 6948
No - they are not the same as the petrol - the driveshafts vary engine to engine.
(1) OEM Left: MARKING 8MN34 was part 3272AH, now replaced with 3272EZ
Exchange 3272AJ
(2) OEM Right: MARKING 8LN18 8LN15 (8LN18), Part 32730Y
Exchange: 32730Z
x 6948
Rear Axle
(6) Is the complete Kit:
OEM: 374879
Exchange Kit: 1681955080
Rear Brakes
(1) Discs OEM: 4249F5 Set of 2
Exchange: 1618860980 Set of 2
(2) Pads
OEM: 425442
Cheaper: 1617247980
Huskyxantia
x 927
Thank you marc, im having an interesting ebay seller trying to tell me petrol ones are the same as diesel , i didn't think they were.
:-D
x 6948
They changed with different build dates but there was a 2.0 petrol (EW10J4S) that has the same replacement part number for the left (3272EZ) and Right (3270Y). To be honest, I generally don't have the time to cross reference part numbers with different models here as this thread is really only for the specific parts for the specific vehicle. I hope you understand. :wink:
Huskyxantia
x 927
Fully understand, its just so helpful having the actual diagrams and the info you give is very helpful.
:-D
wesacosa
(Donor 2021)
x 3
Hi
looking for part number for rocker cover gasket for 97 Citroen XM 2.1TD (XUD11BTE) please
plus if anyone knows if they are still available from PSA
Cheers
x 6948
Item (7), part: 024970, but no longer available from Citroen, but is available from Citroen Classic:
https://www.pieces-de-rechange-classic. ... lasse.html
For 12 Euros
wesacosa
(Donor 2021)
x 3
great, thanks Marc
