- x 6957
Re: Citroen and Peugeot Parts Requests
Here you go:
If it's the gas temperature pipe / sensor that is item (1), part 1618LS, £135.44
Item (4) is the actual DPF Differential Pressure Sensor and that part may no longer be available (1618LP), so they recommend using part 1618Z9, £96.59
Pipes:
(7) is the pipe upstream of the sensor 1618P2 (no longer available)
(9) is the pipe upstream pf the particle filter 1618P4, £19.91
(8) is the pipe downstream of the sensor 1618P3 (no longer available)
(10) is the pipe downstream of the particle filter 1618P5 (no longer available)
Pipes:
Huskyxantia
- x 906
Thank you marc this is amazing you've really helped me so much since I've been a member and i really aprieciate it
Its concerning when you see no longer available for certain bits but i guess there's always a way of acquiring them
Husky.
- x 6957
No worries
- x 22
does this locking wheel nut have a Peugeot part number (eg to see if I can get a spare)?
Code says E N1S6
Off the HDi 407
ta
Code says E N1S6
Off the HDi 407
ta
- x 6957
These can be ordered as a set of 4, but are incredibly expensive - over £100.
If I were you I would dump this type with the 'dimples' and get a 'limpet' set, which will avoid the issue of breaking off.
See my post here for photos - I replaced mine £20 a set and they blend in well.
viewtopic.php?p=659965&hilit=limpet#p659965
A set here for your 407: https://www.ebay.co.uk/itm/124984830353 ... SwD9ZhgVcA
Rhothgar
- (Donor 2026)
- x 221
Marc.
Thank you for your 22nd December reply. Only just seen it. Hope you've had a swell Xmas.
Would you mind checking please to see if 5131.75 is cross-referenced to 96176177 please?
- x 6957
Yes, thanks, chilling out here.
As for 513175 - that's the only reference I have for these mountings, so you may need to find a supplier that has the 513175 part number as a manufacturer reference.
https://spareto.com/oe/513175
Rhothgar
- (Donor 2026)
- x 221
No probs, Marc. Just spoken with PBR and he confirms the front bush on rear subframe is the same for all cars.
Picked one up on Ebay for £13.20 delivered! JACKPOT!
It's about time I had some good luck.
Rhothgar
- (Donor 2026)
- x 221
Whilst I think about it, is 1854.24 the part number for the engine rear lower mount which straps the engine mount (which the intermediate driveshaft goes through) back to the subframe please?
Huskyxantia
- x 906
Hi Marc,
Crankshaft pully part number required plus a diagram if possible of which way it losens & tightens plus toque settings
Many thanks
Many thanks
Husky.
- x 6957
Item (12) Part: 0515T3 £161.40
I'll have to try and get the other info later
Huskyxantia
- x 906
Sorry i missed which car it was for , picasso 2.0hdi dw10.
Thanks again Marc
Thanks again Marc
Husky.
Huskyxantia
- x 906
I take it item 12 is the modified pulley ?GiveMeABreak wrote: 29 Dec 2021, 02:55 Item (12) Part: 0515T3 £161.40
Husky.
Rhothgar
- (Donor 2026)
- x 221
Sorry to pester Marc. Any chance of confirming this pretty please?Rhothgar wrote: 26 Dec 2021, 17:02 Whilst I think about it, is 1854.24 the part number for the engine rear lower mount which straps the engine mount (which the intermediate driveshaft goes through) back to the subframe please?
Huskyxantia
- x 906
Needing part number for the spring clamp that holds the pipe onto the turbo intake side. For my 206cc 1.6hdi
Thanks marc.
Thanks marc.
Husky.
