Citroen C5 Mk1 Navigation system
- x 6945
Re: Citroen C5 Mk1 Navigation system
The MK 1 C5 never had the RT3 installed. That was not until the facelifted Mark II. You will possibly not have the correct equipment / wiring / aerials or the correct BSI to accept this system.
- x 1052
The RT3 system was definitely available on the MK1 C5. Quite rare but definitely available.
- x 6945
Very rare, as most of these early C5s had the Siemens VDO systems.
@Vlado: This isn't something I'm going to be able to help you with as I've never seen one fitted on MK Is. The early incarnations may also of been monochrome as they were without optical cables, I think the RT3 N1 02 was one such version.
jamescarruthers
- x 47
While we are on the topic of the old VDO system in the Mk. 1 C5, is there a known repair for the colour screen which seems to have got a bit dim and lost its colours a bit? For example, when selecting the characters for Sat Nav, it is hard to see which one is highlighted— this is the main time it becomes obvious it isn’t working “as new”; generally you can see what it wants to display but the colour yellow os a real issue.
If the screen is fed with a fibre optic signal, can the ends of the cable be cleaned?
Or, I read a little on here that the video card could be changed. Is this on top of the CD drive?
Or, do I just need a known good screen to replace it with?
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
Vlado
Hello I installed rt3-n3-02 instead of standard rd3 clarion but I have a problem how to connect the bordeaux computer is there someone to help me with that Thank you
jamescarruthers
- x 47
I am very likely not to be able to help you. However, I see that you have posted twice about this “bordeaux”. I think maybe you need a better translator program because this doesn’t make any sense to me.Vlado wrote: 30 Aug 2021, 22:52 Hello I installed rt3-n3-02 instead of standard rd3 clarion but I have a problem how to connect the bordeaux computer is there someone to help me with that Thank you
Maybe you could rewrite your question to have a better chance of some help?
I hope you find a solution.
1987 Volvo 480 ES
- x 6945
Screen seems in stock here James:jamescarruthers wrote: 30 Aug 2021, 21:59 While we are on the topic of the old VDO system in the Mk. 1 C5, is there a known repair for the colour screen which seems to have got a bit dim and lost its colours a bit? For example, when selecting the characters for Sat Nav, it is hard to see which one is highlighted— this is the main time it becomes obvious it isn’t working “as new”; generally you can see what it wants to display but the colour yellow os a real issue.
https://www.proxyparts.com/car-parts-st ... id/566564/
