Peeling buttons...
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
Moderator: GiveMeABreak
Post Reply
tomaskriv
My Cars: 2014 Citroen C4 Grand Picasso
x 3
Peeling buttons...
Post by tomaskriv »
Hi all
I believe some had/has this issue. Peeling buttons. In my case its Vol- button on steering wheel. It was damaged when we purchased the car. Getting worse with time. I know thst the best solution is to replace button with the new one. Still, maybe someone knows good DIY method to fix this.
Ive seen videos on youtube with enamel marker. Will try to get one to see if it relly works.
Thank you all for possible information.
Merry Christmas!
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5646
Re: Peeling buttons...
Post by GiveMeABreak »
You'll find the Chinese often sell 'sheets' of generic radio button symbols / text that you can try.
tomaskriv
x 3
Post by tomaskriv »
Thanks Marc. Tried. Not a big win. Those vinyl stickers start to rub off an you have white sticker on button that peels away....if you try remove that sticker, sometimes it peels even more paint from button.
Will try scrapyards.
C15 Romahome White
CX 20 Polar White
x 5646
I think you'll find the control module is a complete unit - the circular unit that goes around the steering wheel containing all the controls. which would be quite expensive. I would use a bit of opaque paint (to allow the light to shine through at night) if you have a steady hand.
Post Reply
