DanCD
(Donor 2021)
Re: Citroen and Peugeot Parts Requests
Unread post by DanCD »
Thanks Marc,
Its parts 8 and 70 I need
Cheers,
Dan
Dan
Huskyxantia
x 927
Unread post by Huskyxantia »
GiveMeABreak wrote: 13 Dec 2021, 09:46
Huskyxantia wrote: 13 Dec 2021, 09:37 Good morning Marc, another busy one for you, have you a parts diagram of the 2.0hdi xsara picasso gear cables and all fixings ive purchased a new set but one of the plastic gromets had broke ! Its gear stick end.
Many thanks again.
Her you go; if you need any part numbers, let me know the item numbers from below:
Part no.9 and no.7 cheers marc
:-D
x 6947
(7) 2461A1 £57.41
(9) 240511 £7.08
Huskyxantia
x 927
GiveMeABreak wrote: 13 Dec 2021, 10:44 (7) 2461A1 £57.41
(9) 240511 £7.08
Many thanks , your a legend
:-D
DanCD
(Donor 2021)
GiveMeABreak wrote: 13 Dec 2021, 09:44
DanCD wrote: 13 Dec 2021, 09:30 Hi Marc,
Can you give me the part number for the valve cover bolts for my Citroen C4 .4 VTi.
Let me know if you need my VIN again.
Cheers,
Dan
Let me know which items from below Dan:
I need the numbers for 8 and 70. Whilst you're looking can you also get the number for the valve cover itself, 'A'.
Cheers,
Dan
Dan
x 6947
@ Dan:
Item (8) Column Screw Replacement Part: 021217, £1.82
Item (70) (MUL) Flanged Screw Diam 6X100-30, Part: 692569, £2.03
discv
x 24
Unread post by discv »
Part no.help please. Peugeot 207 1.4 petrol VF3**************[VIN obfuscated, can be read by forum staff]
Coolant tank cap & oil filler cap.
Trying to train my daughter to check the fluid levels- and guess what happens!
C4 Grand Picasso 1.6 HDi 16V FAP/DPFS 110, -Auto (DV6 - 80kW) (C4) (DT) (2006-2008)
Toyota Aygo Black 2007 [well almost a french car!]
Xsara Picasso 2.0 Hdi Exclusive 2005
1220 GS Service Van RHD 1973
x 6947
Not sure I can guess what can go wrong with a cap?....
But here you go:
Expansion Tank Cap Item (2) 1306J5, £6.37
Oil Filler Cap item (7) 025864, £12.61
All from Peugeot direct inc. VAT
discv
x 24
Thanks Marc. She forgot to refit them!
x 6947
:-D Oh well, could of been worse - she could of mixed the fluids up!
DanCD
(Donor 2021)
Thanks very much Marc, it's appreciated
Dan
x 6947
No worries
cs101
x 6
Unread post by cs101 »
Please can I get the part numbers of undertray that protects the engine and the Air filter grommets . VIN is VF3**************[VIN obfuscated, can be read by forum staff]. Thanks
x 6947
@cs101:
Item (1), Part: 9808501880 (Front Bumper Deflector) £186.70
Item (2), Part: 9820189780 (Air Deflector Engine) £94.19
All from Peugeot Direct and include VAT, prices as of today.
You vehicle does not have Items (3) & (4).
Rhothgar
(Donor 2026)
x 222
Unread post by Rhothgar »
Please may I have the OE part number for M728 drop links? TIA
