Can anybody enlighten me as to why my BX handbrake doesnt work on one wheel?
The cable pulls the actuating level on the caliper but it has no effect. Whats up with it? My MOT is tommorrow so i guess it'll fail on that.
BX Handbrake
- x 1474
Probably the self adjuster isn't anymore. Try stamping very hard on the brake pedal a few times to see if that wakes it up. If not, have a look at Shane's site, as he had very similar problems with his BX
http://www.aussiefrogs.com/shane
mezuk04
Ian Fearn
- x 94
if fraid cables they wont let lever off fully so hand brake mech cant adjust ,you must not stamp on pedle,just press it hard 3/4 times,if you stamp on it you risk spliting rubber seal behind pedle on dozer valve,also if cables dont release completly calipers do not adjust,so you end up with no hand brake,unhook cable end/s from offending lever,start engine and press pedle hard 3/4 times this sould prove if you caliper/s are adjusting up ok regards malcolm
