Having had to jump-start my peugeot boxer van 2009 some reason now my radio won't turn on always electric windows don't
Kevin gibbins
Unread post by Kevin gibbins »
Hi can someone help had to jump-start my peugeot boxer van now my radio won't turn on nor my eletric windows don't work nor my eletric mirrors please help
x 1056
Re: Having had to jump-start my peugeot boxer van 2009 some reason now my radio won't turn on always electric windows do
Unread post by wheeler »
Exactly where did you connect your positive & negative jump leads on the van?
Hopefully just a blown fuse or 2.
Kevin gibbins
Jump leads straight on battery's checked fuses they ok
Kevin gibbins
Did to the main battery
Dormouse
x 696
Unread post by Dormouse »
Your Boxer van has an under bonnet booster/charging connection and an earth point also to avoid getting to the battery compartment. It is likely you have blown fuses.
The earth point looks like a "wrongly fitted bolt" - it is a longish small bolt that sticks out from the end of the bonnet landing panel.
x 1056
The reason i was asking exactly where you connected is because the proper earth point you are meant to use (shown in the pic above) is not that obvious. The wiper motor bracket looks ideal to use as a negative as its nice clean bare metal, The problem is its on rubber mounts & the several hundred amps from the starter motor passes through the couple off mm thick wire & burns out the main under bonnet harness :shock:
I think later models actually have a warning sticker on this bracket now to warn you not to use it as an earth.
Yes check all the fuses, there may be more than one blown.
