Rhothgar
(Donor 2026)
x 221
Re: Citroen and Peugeot Parts Requests
Unread post by Rhothgar »
GiveMeABreak wrote: 18 Nov 2021, 18:32 This is for your VIN ending 785, so bear in mind it's an exploded diagram.
Yes. That’s the correct VIN. Architect by qualification so do appreciate the exploded diagram hence my concern why it looks nothing like what is on the car!
Cheers anyway Marc. Totally bamboozled.
x 6945
:rofl2: It won't be the first time!
x 1459
Unread post by xantia_v6 »
The gaiter fits over a ring that is part of the strut top mount:
Rhothgar
(Donor 2026)
x 221
xantia_v6 wrote: 18 Nov 2021, 18:52 The gaiter fits over a ring that is part of the strut top mount:
Oh dear! Then it seems that black rubber down stand on the mount has totally failed!!!!
How do Kingas ones match the originals. Are they exact would you happen to know?
Huskyxantia
x 909
Re: Important Information concerning access to PSA parts data
Unread post by Huskyxantia »
GiveMeABreak wrote: 14 Jun 2021, 18:43 Ok
Wheel Hub Bearing
if Item (4) which is (B + (14)), which is the Front Hub Bearing, then part 1606623580 (£118.51)
Cheaper PSA alternative Part No: 1623948880 @ £41.60
Engine Mount
Item (4) part no: 180944 @ £51.02
If anything else, let me know Colin.
What model would this cover ? Reason i ask , ive done 2 bearings on my 206cc 1.6hdi both have failed
Might be fake parts having a issue at the mo with ebay seller, whats the correct torque setting for the main hub nut im seeing on the net 96nm up to 350nm, ive got a slight vibration when slowing down not brakes either there all new.
:-D
x 6945
Diagrams and part numbers are only relevant to the specific vehicle in the original post and it's not practical for me to go back on old posts.
As you're a donating member, just ask for your own part numbers. Tell me what it is you want part numbers for here and make sure you pop your VIN up for the 206. :wink:
Huskyxantia
x 909
Front wheel hub bearing torque setting vin. VF3**************[VIN obfuscated, can be read by forum staff]
:-D
Huskyxantia
x 909
Hi, its the front hub nut torque im after. 36MM Nut , very conflicting on the net about the torque
:-D
x 6945
Here you go:
The Wheel Hub (2) is part: 330785
The Hub Bearing (3) is
OEM Original: 335016 £144.01
Peugeot Approved Cheaper alternative: 1681934780 £27.23
Prices as of today from Peugeot inc. VAT.
The Driveshaft Nut is (M24X150) 32.5 da.Nm
Huskyxantia
x 909
Thanks marc
Have you anythimg about the rear hub ? Mine has the magnetic ring with bearing fitted all in one part numbers and the torque of the bearing hub nut too, dont think mine are tight enough on the rear.
:-D
x 6945
Here's the torque settings for the rear suspension
ReferenceDesignationdaNm
(1)Rear flexible mounting to body fastening11
(2)Front flexible mounting to body fastening11
(3)Torsion bar (Face and threads greased )2.0
(4)Rear shock absorber fastening to yoke (Face and threads greased )7.0
(5)Rear shock absorber fastening to arm15
(6)Rear hub fastener (Face and threads greased )20
(7)Anti-roll bar lever bolt3.5
Huskyxantia
x 909
Brilliant .Thank you
:-D
Orchid70
(Donor 2021)
x 6
Unread post by Orchid70 »
Hi Marc
Im looking for correct FAP fluid for refill. VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thank you!
x 6945
Orchid70 wrote: 23 Nov 2021, 21:25 Hi Marc
Thank you!
With a build date of 12510 you need Eolys EXTEND for the C5 X7.
randomandy
Peugeot 207 ABS sensor part number
Unread post by randomandy »
Hello!
On my 2007 Peugeot 207 (1.6HDi 9HX) the ABS light on the dashboard illuminates every time the car is started. Having a poke around with the PP2000 it reports:
Permanent fault. Right-hand rear wheel sensor signal fault. Open circuit or short circuit to positive or short circuit to earth.
Could one of you kind folks provide me with the correct part number for the replacement?
-Andy.
