Hi can anyone help, I've got an 08 Citroen Dispatch 2.0 LWB, it's had an air suspension warning light on for months now but suspension has worked fine, ride height etc all correct, pump comes on every now and again but only for very short periods etc.
Today it has decided to jack the rear suspension right up? The manual button in the rear doesn't seem to do anything I do hear a beep from the cab but presume that the air suspension fault light coming on again.
Is there anyway to manually reset the suspension?
Thanks in advance
Citroen Dispatch Air Suspension
- New User
- My Cars: Citroen Dispatch 2.0 LWB 2008
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: Citroen Dispatch Air Suspension
Hi, no, there's no 'reset'. It needs Diagbox or Lexia on it to get the fault codes out first of all, as it may be the height correctors on the rear axle that are shot. If you can get the fault codes it will help and save a lot of guess work.
Just be warned not to go underneath the vehicle unless independently supported if you are having pneumatic suspension problems - as if the system is fault - especially the height corrector, it may cause the vehicle to drop like a lead balloon and crush you. I say this just in case you were thinking about checking or lubricating the height correctors.
- Gregor
- My Cars: Actual fleet:
- C5 III tourer 2.0 HDI RHF (103kW 2010)
- P208 XY 1.6 THP (115kW 2013)
- GSX-R 750 (110 kW 2008)
Past members:
Xsara 2.0 VTS (2001)
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
Zastava 750 (1968) - x 14
Is an Hydractive suspension an option on C Dispatch models in UK???? I have never heard for this in our region. I would love to find one to replace my old C5X7!
Driving Citroen is a diagnose!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
It's not Hydractive Gregor, just air cushions (bags) and a compressor that is used for some commercial vehicles and C4 Picassos - but only for the rear - not the front which has standard struts and springs.
- Gregor
Past members:
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
