Lots of us have had the rubber elbow (height correctors and other locations) split or perish.
Part no. is 5280 P5 Hydraulic return tube sleeve, diam.3, rubber.
Still shown as available.
If you google it, there are quite a few suppliers, eg
https://www.bxparts.eu/en/hydraulic-ret ... antia.html*
https://www.online-teile.com/citroen-er ... anguage=en
https://peugeotcitroendsparts.com/peuge ... ve-5280p5/
*could be a remanufactured item
On this sort of thing, the Hydraulic pipe lining (joint sleeves) appear in the Piping Brackets section of SB Parts, and are still all available:
96 085 783 for 6.35mm unions
96 085 784 for 4.5mm unions
96 085 785 for 3.5mm unions
Citroen hydraulic return pipe 'rubber' elbows & union joints
- white exec
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: Citroen hydraulic return pipe 'rubber' elbows & union joints
Just for info:
5280 P5 is still available from Citroen as of the time of this post Chris - it's not showing as NFP, and if it was, PeugeotCitroenParts would not have it either as they get any parts from the same place.
- white exec
I mis-read that this morning.
Yes, still shown as available. Post above edited.
Thanks, Marc.
Thanks, Marc.
