- quintet
- Donor 2023
- My Cars: 2.0 hdi Peugeot 307
- x 41
Re: Important Information concerning access to PSA parts data
Hi, could i put in another request for some part numbers please, each weekend i seem to discover my car needs more stuff fixing! Rather than making separate requests i figured it would be better to ask for all that i currently need info on in one go although the jobs will only be done when time and money are available......so some point next year at this rate!
osf antiroll bar link. There seems to be a couple of different types, or at least superseded versions and an ebay search throws up different types which apparently all fit.
osf lower suspension arm/hub ball joint
front brake discs
front brake pads
rear brake discs
rear brake pads
rear shock absorbers
rear silencer exhaust mounting
and if possible the type of battery, ie 027, 068?... obviously i can get a battery quite easily so i don't really need apart number but my car came with the wrong one on it so i don't know what it should have.
vehicle details VF3**************[VIN obfuscated, can be read by forum staff]
rp number 10334 89
If you can get all these part numbers i'd be very grateful but i get that there's a lot and so the antiroll bar link, lower ball joint and the battery are the priority, chances are the rest of the work will be done next year anyway.
front brake discs
front brake pads
rear brake discs
rear brake pads
rp number 10334 89
Music keeps me going.
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
I'll sort this lot out for you in the morning.... ... when I've recovered the will to live..
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, here you go, all prices from Peugeot correct as of this post and include UK VAT. Prices are for individual items unless stated otherwise.
Antiroll Bar Link
OEM: 1614281180 £51.36
Cheaper: 1634890780 £8.38
Lower Suspension Hub
330785 £144.01
Front Brakes
Front Brake Pads
425259 £81.58
Front Pad Shim Set
440719 £23.21
Front Discs (set)
OEM: 1647868480 £151.01
Cheaper: 1618890480 £58.43
Rear Brakes
There are 2 Types of Assembly:- Bosch or Lucas TRW - Discs are the same but pads and callipers are different. I've listed Bosch for now.
Rear Brake Pads (Bosch)
OEM: 425476 £72.18
Cheaper: 1617272480 £28.32
Rear Brake Discs (DIAM 249 EP 9)
OEM: 424934 £131.94 (each)
Cheaper: 1619237880 £92.86 (each)
Rear Shock Absorber
Rear Suspension Shock Absorber (note original part not available, so they've proposes an alternative part)
Alternative Strut: 9811403880 (Must be replaced in pairs. Damper supplied without support and without bump stop) Each £88.38 (each).
Cheaper: 1623318180 £41.11 (each)
Rear Exhaust Mountings:
Item (2) 171352
Item (2) Cheaper: (171366)
Item (3) 1755L0 £9.04
Item (4) 1755L1 £19.46
Item (5) 179749 £25.13 (Kit of Items 2, 3 & 4)
Battery
You have a L2D - 540A - 60AH originally fitted.
Original: 1629085480 £141.92
Cheaper: 1609232680 £108.30
Antiroll Bar Link
330785 £144.01
Front Brakes
Front Brake Pads
425259 £81.58
Front Pad Shim Set
440719 £23.21
Front Discs (set)
Rear Brakes
OEM: 425476 £72.18
Rear Shock Absorber
Item (2) 171352
Battery
- quintet
- Donor 2023
- x 41
Thank you for all this marc, sorry it was such a long list! unfortunately what i wrote was misleading as well! rather than stating "hub" in my previous message i should have just said ball joint and i ought to have remembered there can be different brands of brake components...and guess what, my car has Lucas but having said that looking at the prices for dealer budget parts they are just as cheap as they are on line, i know the quality won't be up to much but this car needs so much work i need to spread the costs out. As for the battery my xantia has a 540 ah battery on it so if that gets scrapped then i'll use that if it fits ok.GiveMeABreak wrote: ↑16 Oct 2021, 22:49 I'll sort this lot out for you in the morning.... ... when I've recovered the will to live..
Once again, thank you for getting all this information for me, it's very much appreciated
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries, here you go:
Steering Ball Joint
Item (5) OEM: 381750 £50.11 each
Cheaper: 1607316180 £10.90 each
Lucas Rear Brakes
Rear Discs
OEM: 424934 (DIAM 249 EP 9) each £131.94
Cheaper: 1619237880 each £92.86
Pads
OEM: 425467 £72.18
Cheaper: 1617250480 £20.10
These are all Peugeot original parts for OEM items and the Peugeot approved cheaper parts. If you find the prices for the cheaper parts are comparable to other aftermarket offerings, I would stick with the Peugeot cheaper parts as they at least have the guarantee of being up to the same standards - and personally speaking I would avoid anything from ECP.
Steering Ball Joint
Lucas Rear Brakes
Rear Discs
Pads
OEM: 425467 £72.18
- Donor 2023
- My Cars: Peugeot 3008 GT Line 1.6 HDI Auto.
- x 5
Marc, thank you very much for your help as all sorted now.GiveMeABreak wrote: ↑14 Oct 2021, 17:30 Ok so that is part 6598JW and is a mere £165.67 inc. VAT from Peugeot.
- Donor 2023
- x 5
Hi Marc,
Any chance I can get a part number please for the fuse box/battery state of charge unit that sits on top of the battery as I have been told it is corroded?
2014 Peugeot 508 2.0 HDI 163 Auto
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
Many thanks.
Many thanks.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Sure, here you go:
The Battery Charge Status Unit is item (30). It has been replaced with a superseded part now.
Part: 9815524580, priced at £102.40 direct from Peugeot.
Prices as of this post & include UK VAT.
- Donor 2023
- x 5
Thanks Marc.
Do you also have a part number for the fuse box that sits on top of the battery? It's called a battery control module fuse box or something along those lines.
Thanks again.
Thanks again.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Do you mean the actual engine fuse box?
But bear in mind the engine fuse box needs configuring to the vehicle on this model if being replaced!
Item (1) is the engine Fuse box, part: 9810719480 £333.24 inc. VAT
- Donor 2023
- x 5
This is the part I am looking for but I obviously need to ascertain the correct part number before ordering:
https://www.ebay.co.uk/itm/2010-2015-PE ... 635-2958-0
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's not the same thing. The part in your link is a protection and management unit and is not the correct part number for your vehicle.
9665878080 item (1) is the correct part number if this is what you are after. These are very specific, so you need the correct one.
- Donor 2023
- x 5
I'm just going off what the family member was told by the Citroen dealer, which was corrosion in the fuse box on the battery. I'm guessing people refer to it as different things.
It's within this unit that we replaced a corroded ABS fuse and then the ABS started working again, so the fact they are saying it's corroded makes sense. I will ask them to clarify.
Thanks for your help.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, so I'm not too worried about that - it's just that what you linked to is different to my post prior to the one above. They are completely different things.
One is the engine fuse box itself - and the other is the supplies and protection management unit - they're not the same thing, so just wanted to clarify that with you before you go buying something that may not be correct.
Hi Marc
Could you grab me a couple of part numbers please
Front Shim Set
the section of the exhaust that has the flexi pipe in, it's towards the front of the car
Many thanks
Front Shim Set
Many thanks
