DS7 - Water in rear light
Post Reply
TheBadger
My Cars: Now: 2018 DS7 Crossback Ultra Prestige PureTech 225 Auto, Absolute Red
Replaced: 2016 DS4 Crossback, BlueHDi 180 S&S EAT6 Auto, Ink Blue Metallic
Replaced: 2013 DS4 HDi 160 Manual DSport, Babylon Red
x 5
Post by TheBadger »
Washed my car at the weekend using a hose and noticed afterwards that some water had made its way into the passenger side rear light. I called the dealer and it's a known issue and the subject of a notice issued to dealers by DS. It's being replaced under warranty next week while I wait. A 30 minute job, apparently.
If anyone else has the same issue don't be slow to report it and get it fixed.
FOZEY
My Cars: DS7 CROSSBACK PERFORMANCE 180
Re: DS7 - Water in rear light
Post by FOZEY »
Yes I have the same problem rear left. Booked in for replacement next week.
Dormouse
(Donor 2022)
My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly)
x 666
Post by Dormouse »
Our Ducato/Relay/Boxer has the same issue. I have drilled two small drain hole in the new Light units we fitted and used Vaseline on the electrical connectors. Water ingress into light units seems to be a perennial problem so look out for it.
FOZEY
Post by FOZEY »
I have 2 years warranty left so drilling is out of the question at present. This rear light cluster I understand is around 800 quid so you would like to think it was bomb proof lol!
Dormouse
(Donor 2022)
x 666
Post by Dormouse »
You would like to think so
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5739
Post by GiveMeABreak »
Just had my high level rear brake light lens replaced under warranty due to water ingress (spider stress cracks where the rear washer jet protrudes) - they now keep these as 'stock items' my manager friend told me, so that tells you something.
Poshborer
New User
My Cars: Ds7 crossback
Post by Poshborer »
Does anyone know how to remove the tear light so I can drill drain dry and seal unit
Many thanks
Goff1
My Cars: DS7 (Citroen by any other name)
Post by Goff1 »
Same problem, DS7 went for it's 1st MOT, examiner showed me the water collecting in corner of passenger side rear light, 3 year warranty running out next day so got on phone to DS dealership straight away, told me it was a common problem & would be fixed under warranty. Surely if this is such a common fault it should be a recall or a permanent remedy offered. Owners shouldn't have to think about drilling a drainage hole or be afraid to hose their car.
C15 Romahome White
CX 20 Polar White
x 5739
They won't bother for that unless it's safety related. They didn't even issue a recall for the C5 X7 steering rack debacle - many of whom are on their third rack.... including 2 original new ones in my case.
FOZEY
Post by FOZEY »
UPDATE. Phoned nearest DS aftersales repair centre (53 miles away in Fareham) They asked me to send some pics to them. They ordered the part which was on back order so came from France. Just under 2 weeks later was replaced in 20-30 mins no drama at all. Great service from Yeomans citroen Fareham!
C15 Romahome White
CX 20 Polar White
x 5739
Good result - and important you do this in my opinion, as taking it back may be a hassle, but at least they have a record of incidents, as they have to complete a form for warranty repairs and this gets fed back for future improvements.
Goff1
Post by Goff1 »
DS dealership Weston Super Mare changed rear light under warranty, again admitted its a common problem, apparently the replacements being fitted have had the issue rectified. This is OK unless you are out of your warranty period & have to fork out £££££'s for a new one & the labour to fit.
C15 Romahome White
CX 20 Polar White
x 5739
And extra lucky if you're in the UK as we get 3 years warranty here - only 2 years in France....
FOZEY
Post by FOZEY »
So 5 months on the the right hand rear light cluster has now filled with water so another replacement and a 100 mile round trip to get it done..................................... It was the left last time
Macron
New User
My Cars: DS7 Crossback
Post by Macron »
Open the boot and check the level of water inside the rear light assembly. Drill a small hole inside the boot lid next to the rubber seal into the rear light assembly below the water level. The water will gush out. It then takes about one week to de-mist the lens.
Post Reply
