While searching the area towards the front of the left hand side (passenger) wheel arch, I found this piece of hard plastic floating around on its lonesome. I will try to upload a photo of it in a moment. Is Marc able to upload a picture of that area (parts diagram) behind the front plastic "bumper" and the left wheel arch which may help to see wheel it should fit.
This search was being carried out to assist in finding a rumbling sound which only occurs on a rough road surface. Smooth surfaces do not give rise to the rumbling. I doubt if it is a bearing, especially give that the car has travelled 100k kilometres on paved roads, albeit too many with coarser aggregate tarred thereto.
(have given up on loading the photo)
Orphan part from my C5
Ceenine
- x 17
Re: Orphan part from my C5
The part no. for this item is 9671918380
- x 6956
1) Just use the Full Editor & Preview button to edit your post.
2) Then, at the bottom press the ATTACHMENTS button.
3) Next, press the ADD FILES button - this will allow you to browse and select pictures from your phone or PC.
4) When the picture has uploaded, you will see it listed, so all you have to do is put your cursor at the spot in your post where you want the image to be placed (you may have to put a few extra line spaces in if you want it under the current text), then press the PLACE button next to the uploaded image.
5) The system adds the code for you.
6) If you want, you can also use the FILE COMMENT box to add a caption
7) You can use the PREVIEW button to see what the post will look like
8) Hit the SUBMIT button when done.
You don't need IMG tags - those are only for externally hosted image sites.
- x 1432
That part no is not recognised.
Here's the front bumper and wing area / liner, any help?
- x 3534
At a complete shot in the dark, I'm guessing it's going to be the plastic cover that protects the subframe to body bolt that sits within the front wheel arch. If I'm right I think that's worth at least 50 points
Ceenine
- x 17
I was thinking 53, however I reserve judgement until I investigate
Ceenine
- x 17
Richard, Thanks for those diagrams. I am sure that there will be an occasion when I need to pull the front off the car, unfortunately. I find with these diagrams that they are especially useful in relation to the fixings. Just determining the location of certain undertray fixings constitute an intelligence test. That’s probably why they challenge me.
BTW, I found late last night that the delinquent object was the battery”wedge” which had fallen through. I am hoping that this was the cause of the vibration when driving on coarse bitumen.
Don
Don
Ceenine
- x 17
Thanks Marc
Thanks Marc
