Electric Vehicles-Infrastructure
Re: Electric Vehicles-Infrastructure
Even the Northumberland Gazette has reported this story
All new homes and offices in England will have electric car chargers
Not the only ones...the story is in all the "papers" and on the TV, and across the pond in the US.
..and it arose out of a little utterance from The Parliamentary Under-Secretary of State for Transport
(Rachel Maclean) Thursday 9 September 2021
https://hansard.parliament.uk/commons/2 ... 4F2D7200E8
I thank my hon. Friend for all the hard work she has done on her ten-minute rule Bill, which addresses a vital issue. We in Government are going to act. We have heard her calls and those of her residents. We will publish our consultation response on requiring all new residential and non-residential buildings to have a charge point, and we intend to lay legislation later this year. We have also confirmed our intention to mandate that home and workplace electric vehicle chargers must be capable of smart charging.
Dormouse
x 696
Unread post by Dormouse »
I found this article while trawling the net. See if you like it.
x 2938
Very interesting and beautifully filmed,
Dormouse
x 696
yes, definately above the average dross
x 5675
Best of all, not American!
My lot...BP Pulse ( one of the memberships I have) have just announced a new set of ultra-fast chargers.
Never plugged the Leaf into a charger above the standard 50kW ordinary rapid charger. I presume it would only charge at the rate the car tells it to even if it was plugged into an ultra fast 150kW. Quite enough no need to go overboard with ultra rapidness of charging for me. I don't have an expectation that electric cars need to "fill up" as quickly as fossil fuel cars, and I have a fuel station at home. Nearest petrol is miles away.
BP Pulse opens ultra-fast charging sites in Scotland
BP Pulse has opened two new ultra-fast charging sites on the M8 motorway at bp pulse’s Harthill services in Scotland. Situated on the Edinburgh to Glasgow corridor, the sites feature ten 150-kW chargers servicing the east-and west-bound carriageways near Harthill, Lanarkshire.
I like these, simple, dumb, not well publicised and free
Had a bit of "can't remove the chademo plug from the car anxiety" tonight at an Electric Blue Charger. Somehow the charger menus let you get to a point where the charger was plugged into the car and ready to go, but wouldnt start because of an authorisation failure. I imagined the chargers would be set up to allow bank card payment and that would be the authorisation to kick off the charge. But no.
So at that point, the charger was in limbo, set up to start charging, including locking of the chademo plug into the socket on the leaf, but no way of either fully starting the session or ending it.
Yet another instance of not having a smart phone or any ability to download the app causing restriction of access to chargers, but in this instance the BBLEAF, charging plug locked to the car, and no way of getting it out!
Luckily there was someone at the end of the 24/7 help desk, she was very pleasant and started the charging session remotely to get over the impasse. When the car reached 80% as normal, it ended the charging session, and hip hip hooray relief that the chademo plug could be removed, and we weren't left tethered to the charger overnight sleeping in the car till the cavalry arrived :-D
Should have stuck to our usual comfort zone of tried and tested charging up stops, rather than checking out a new charger just for "fun". :-D
Dormouse
x 696
Could have been fun! NOT. I have this picture of you, Giles like, driving home trailing a wall box and lots of wire behind you.
x 8147
A different image crossed my mind with Mr and Mrs Falcon asleep in the car at 06.00 as the council road sweeper came by sweeping up the leaves!! :-D
Dormouse
x 696
Should that not be Leafs in this case? Or am I being too pedantic? Poor Falcons.
x 2938
In one of those videos Neil posted there was mention of not plugging in until the payment was set up or the charge might fail.
Have you got a home charger Neil or do you rely entirely on those out and about?
Gibbo2286 wrote: 17 Sep 2021, 09:38 In one of those videos Neil posted there was mention of not plugging in until the payment was set up or the charge might fail.
Up until April this year there was a freebie 7kW charger, like the one at Etal Village hall, so no point using our own electricity, and I could put up with the mild inconvenience for free charge. They bumped that up to 35p/kWh so that is when I got out the plug-in granny cable to charge up from a domestic socket, and thats what I use from home now. Probably around 17p kWh on our current Scottish Power tariff.
Still some freebies around...all 7kW. Northumberland County Council contracted out management and maintenance of "their" rapid chargers which remained free up until June 2021, but are now all the same as the rest of rapids on the road at 35p ish/kWh. Not that much different from petrol. Depending on the car and how you drive it its around 4 miles/kWh. Showing on the dash 4.5kWh right now but it maybe drops to 3.5miles/kWh in winter.
Interested to hear of your Zoe story. It really is a great price for that car. Comparable costs of a used ICE right now of similar year and size, ie a Renault Clio 14 Reg low milage, are retail north of £6,000. It could be argued as the Zoe gets older the battery lease gets better value. Like I say though you have to trust that should the Zoe reach 75% battery capacity Renault stick to their side of the bargain. I wouldn't bank on a no quibble battery replacement from Renault.
One of the vids I linked too mentioned the thermal management of the Zoe battery resulting in less degradation which is a good thing.
The degradation is a matter of physics/chemistry based on the number of charging cycles, mileage, age, and the optimum temperature being maintained. Charging in the range 20% to 80% is gentler on the Li-ion battery than a regular 100% charge, I guess with my Leaf being low range, and our typical journeys requiring an on the road charge usually at a rapid 50kW DC charger, it isnt the optimum. Shorter journeys and you could run the car on a single home charge for a few days.
I would say 50% at home 50% on the road would be our typical charger activity now.
x 2938
Having already got solar panels working very well I might just plump for a home charger with the government grant when the Zoe arrives and I've given it a trial.
The company who installed my solar are a registered supplier of the chargers and the workmanship was excellent.
Still waiting the the battery lease change over to get sorted.
x 2938
Well that was disappointing, just asked for a quote, they say they don't get involved with the grant scheme only fit Zappi and at a fixed price of £1500. :shock:
