My dad's Xantia is struggling to start at the moment and ran on today as if he still had the key in it.
Sounds like a dodgy stop solenoid to me. I will check the wiring but I need to know whether it is replacable on this model and how easy it is. It has had the damned immobiliser immobilised!
Xantia 1.9TD 1997 Running On
jeremy
- x 94
fastandfurryous
- x 4
I think the running on and the struggling to start are seperate problems.
Starting issues are 90% dead glowplugs. Even one dead can cause nasty problems. After that, look at injectors, and possibly pump timing. Maybe air in the fuel.
Running on can only be caused by a dodgey stop solenoid. It sounds like it's not seating properly.
That said, it might be that the rubber seal on the end of the stop solenoid plunger has swolen, and is taking an age to open and close. I'd have the solenoid off and have a good look at the seal.
David.
David.
jeremy
- x 1477
Bad luck - if it's got an immobiliser then the injection pump has to come off to grind the security bolts out to remove the stop solenoid. Ouch. Sadly it does sound like the solenoid is on the way out - this is the only thing that can cause running on (other than aforementioned oil ingestion, but this would cause very rough running and lots of smoke).
