D.P.F. fault code .
biddy1780
New User
D.P.F. fault code .
Unread post by biddy1780 »
recently my van went into limp home mode due to a code that says D.P.F. filter needs replaced . i took filter off and cleaned with Wynns of car D.P.F. cleaner . and it looks brand new . but fault code will not go away . Does this mean new D.P.F.?
x 6945
Re: D.P.F. fault code .
Hi and welcome.
Do you happen to have the exact fault code?
x 1940
Did you use a diagnostic tool to "tell" the car that a new DPF has been fitted?
Did you also check the level of your Eolys?
x 6945
Yes, both good points Paul mentions:- the engine ECU will not know you have cleaned the DPF as it uses the weight of the additive that has been dumped into the filter over the miles. It does not use the differential pressure sensors alone to trigger the warning. So cleaning the filter is akin to replacing it - and the engine ECU needs to know this to cancel the warning. And again, it is the best time to top up the additive tank and reset the additive counter to zero.
You will need Diagbox or another suitable diagnostic tool to do this or the warning will not go.
