dpf adative reset
dpf adative reset
hi to all
peugeot 3008 hdi how do you reset the dpf adative reset using diagbox v9.91
david
david
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
Re: dpf adative reset
Usually this will be done via the engine ECU options and may require priming as well as resetting the counter to zero once you have topped it up. Don’t reset it unless you have actually topped it up or you will face issues down the line.
- My Cars: Peugeot 3008
Step 1- Select Repair and test by ECU
Step 2 - Select the Engine Management ECU
Step 3 - Select Repair
Step 4 - Select Pack Repair
Step 5 - Replacement Parts
Step 6 - Select Filling of the Additive Reservoir
Step 7 - Enter Mileage (in kilometers)
hi to all
thank you for your help
how do i prime the the system
david
david
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
If it is required it will be in the same menu under the engine ECU.
thank you
hi to all
followed the following
it did not work what am i doing wrong
david
david
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Can you explain what happened when you followed the guided process? What makes you think it didn't work was their a message and if so what was it?
Thats exactly what I did when I did mine, it isn't one of things that have been removed from the newer versions of Lexia is it? I used 7.57 to do mine.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
The procedures can vary slightly according to vehicle and engine and therefore type of engine ECU fitted as well as the software version of Diagbox. V7.62 is a good version to stick at for vehicles 2015 and earlier.
hi to all
i am using diagbox v 9.91 and it would not except the reset of the dpf or prime the system and it would not clear the fault
david
david
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
I'm not too sure whether this is because of limited capability of the 'modified' software for this version. What year is your 3008 or better still the VIN. If early enough I think you would do better with an earlier version of Diagbox - but I'll know more when I have the info from you.
The unofficial V9.** removes lots of configuration and programming abilities without a PSA account and even then may be problematic with a clone device. It's really only good for code reading and some procedures - which will vary from model to model. So you may not be able to do it.
good afternoon
peugeot 3008 hdi 2017 vin VF3**************[VIN obfuscated, can be read by forum staff]
david
david
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Ok, that's confirmed it as you have the later model 3008 and therefore being a May 2017 build it will need Diagbox V9 which you already have David.
I think your only recourse is to book it into the dealers - I think H J Phillips & Son Ltd in Llanelli is the nearest Peugeot now Howards are no longer a Peugeot dealer - but you could try Citroen Bassetts as they should also have the same diagnostics systems to do this.
The resets on some systems can be problematic at best - and I've known people with issue after issue with the DV6C engine resets. So a dealer reset may be your only resolution.
good afternoon
i do have a peugeot account and to download the diagbox software and use on one vin will cost
£55 for 2 weeks but a bassets technition is coming to do the diagnostic on monday
david
david
