Engine Repair Needed. Hundreds of faults listed.???? What Could be the cause?
craigh
x 6
Re: Engine Repair Needed. Hundreds of faults listed.???? What Could be the cause?
Unread post by craigh »
GiveMeABreak wrote: 01 Feb 2019, 10:49 I've actually only just seen this post, (I wasn't actually subscribed to this Sub-Forum :roll: so that was the reason I wasn't getting notifications), so wasn't ignoring the requests.
Glad you have sorted the issue - but there are some issues with accessing data for some DS Vehicles at present - the VIN is not being accepted on a lot of these. I have fired off a support request to PSA Groupe concerning this.
No problem Marc. All fixed now and running great again.
What is it that you do with the Vin Number? and what information can you get from this from PSA?
Craig - 2012 Citroen DS5 2.0 HDi Hybrid 4 x 4
x 6958
I use it to determine exact model and options which can aid us in a more accurate response.
Joanne Whitfield
Unread post by Joanne Whitfield »
@craigh which garage did you take your car too please? I have the same problem.
Dormouse
x 696
Unread post by Dormouse »
Wish I had found this thread at the start of my problems with our 3008 Hybrid4. A failing battery was masking a basic problem which itself only became apparent after I had sorted out the 12v service battery issues. What a font of knowledge this forum is -= it just takes a bit of perseverance to get there, as I have discovered.
Dormouse
x 696
Sorry Joanne for hijacking your question but hopefully we can get some answers for you. cheers
Dormouse
x 696
If you have a list of codes/suggested faults/issues please put them up here and the little knowledgeable gnomes will be able to guide you and suggest a garage near you. There is a section devoted to garages near to you in the listing board. If you can't find it, just say and we will help.
Joanne Whitfield
My partner changed my battery which led to.numerous faults flashing up and error codes relating to electrical circuit fault.
Initially the remote key wouldn't open the car, or periodically when it did it would fail to start the car or cause other problems.
The BSI reset wasn't carried out, so I suspected they may be phantom errors, and aside from electrical circuit fault error flashing on start up, the car then drove and performed as it should.
Recently the brake caliper stuck on and various other warning messages and lights are now on, and the alarm has since started to sound periodically of its own accord. The brake pads have been changed and caliper sorted, DIY job, but the lights remain despite going off after changing pads etc.
I'm keen to know which garage Craigh went to as I think it's near enough to me and if they have experience seems sensible to go there
x 1352
Unread post by xantia_v6 »
Craigh has not been active on the forum since his issues were fixed, so he may not see any replies here.
x 5592
Joanne,
You might try sending him a PM that he may respond to.
The only place I am aware of in the vicinity is Croxdale Citroën.
Never used them but have not heard anything positive about them although that was years ago.
Except the mechanic I use worked for them when he first came from Poland so is Citroen trained and it shows.
x 7162
Joanne Whitfield wrote: 31 Jul 2021, 23:40
craigh wrote: 15 Jan 2019, 08:59 ***********Update**********
Car is booked in tomorrow with Independent Citroen Specialists based in Thornaby, Stockton, used them before and know their stuff so will hopefully find the problem tomorrow.
This will be the garage craigh used
craigh
x 6
NewcastleFalcon wrote: 01 Aug 2021, 10:40
Hi All
Have just responded to Jo Pm and have confirmed the garage was Citromatic in Thornaby.
