Hi
i have the picasso c3 2012 , lately i have this problem when it whould over heat if i stand in red light or standing anywher , if i drive it, it wont over heat.
it shows the warning light within 20-30 sec since i start the car .
last time it did this it was like 6 month ago , i changed the thermostat and problem solved , i have tryed also today to raplace the thermostat , but no luck.
i have change the temp sensor with the thermostat, what else could it be?
fyi i did timing and water pump few month ago , since then , i had no problem .
picasso c3 over-heating?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: picasso c3 over-heating?
When you did the water pump, did you drain the cooling circuit, as this should be done - so the next logical question is have you filled it with the correct coolant and then bled / degassed the coolant circuit? If you haven't, then you may have the wrong type of coolant in and / or an air lock in the circuit that can lead to overheating.
i did drain the cooling ,
i did more digging today.
it wont over heat if i drive it , or even stand without the ac on .
but , if i put the ac on on idle , 5 sec exactly after the fan go in , it goes out , then the warning light with stop light come on.
the temperture by the ecu (obd2 connected is 80c).
i drove it today , put the ac on , it showd the temp light warning and stop , and after 10 secends its disappear.
again -if the ac is off , it will not overheat , if i turn it on like 15 secends it will throw the warning
Btw - i replace the radiator today , no luck as well
ok so i left the car for like 5 hours , came back now , start it up , turn ac on , 30 sec after , warning showed up , (engine cold-like 18deg cel outside
is there is any temp sensor on the radiator or somewhere else , beside the one that on the theremostat?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
What is your vehicle's VIN? I need this to identify your exact engine and system. Please post it here (it will be masked automatically when you submit your post).
Maby the coil on top of the radiator is controlling the temp sensor too??
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
See my post here for a C3 for the water temperature sensor location item (2): it is the same part number and marking as the one in that post.
viewtopic.php?p=632862#p632862
Yea i have replaced it , and im pretty sure i have found it , the coil on top of the radiator is defective , and it couse the temp light, will update soon
