C5 x7- Fuel rail pressure switch (Help !)
Post Reply
sebahattin
My Cars: Citroen C5 X7- (2011) 1.6 eHDI
VIN : VF7**************[VIN obfuscated, can be read by forum staff]
Post by sebahattin »
6 months ago, I changed the filters and engine oil. I don't remember the brand of the fuel filter, I'm guessing it's of medium quality. And there were 2 injector errors in the checks.But the performance was not bad.
After 1 month, there was a loss of power during driving, when checked, we found that 4 injectors also gave errors and renewed them. I drove smoothly for 2 weeks.
The car then slowed down, giving an error while driving. p 1621-control unit returned an error. I drove 2 months like this.
For the last 2 months-p 1621-control unit and p 0191 (fuel rail sensor-low pressure) -p 0193 (fuel rail sensor-high pressure) have been giving errors in order. On the instrument panel, the engine failure lamp-service lamp-ESP gives the error together.
I changed the brake pedal switch after researching from various forums, but it not disappeared.
Finally, I replaced the fuel filter with the original, but my problem not disappeared.
Do you think the ECU can also be a problem, or I should change the Fuel rail pressure sensor ?.
If you can help I'd appreciate it.
leithant
Donor 2023
My Cars:
x 4
Re: C5 x7- Fuel rail pressure switch (Help !)
Post by leithant »
I had the the pressure sensor give the same issue.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
sebahattin
leithant wrote: 08 Jun 2021, 12:04 I had the the pressure sensor give the same issue.
has sensor replacement solved your problem?
leithant
Donor 2023
My Cars:
x 4
Post by leithant »
Yes it did. Not that it guarantees yours is the same.
95 Peugeot 306 S16
sebahattin
leithant wrote: 08 Jun 2021, 14:18 Yes it did. Not that it guarantees yours is the same.
Has your ECU fault disappeared after that?
sebahattin
Changed sensor. İt solved. Thx.
leithant
Donor 2023
My Cars:
x 4
Post by leithant »
Great! How much was the part for you?
95 Peugeot 306 S16
sebahattin
İt was 50 usd.
Post Reply
