C5 x7 2.0hdi 103kw,2011year stagger when hit the gas and strange noise
- My Cars: C5 x7 2011,2.0hdi 103kw
Hello dear friends,
I am owner of C5 x7 2011year,2.0hdi 103kw
I have several issues with my car.
First of all,it started to lag when i hit the gas pedal like for amilisecond it doesnt have power then immeadiately get the power.
I had it taken to the car shop where they connected it to the diagnostics and showed following errors
-p1351(connected with engine heaters)but he mecahnic said it is not so important for the issue
-p11aa was the second error whic is connected with the turbocharger(he told me it is vaccum valve on trubine)i changed it and doesnt have any more that error
But the staggering conntinued to happen,sometimes.To highlight,it doent happen all the time...it happen sometimes,maybe 10days wont happen and than out of blue it happens.
I had it taken to other mechanic,and he told me it could be fualty injectors of faulty turbo.
But nobody cant for sure tell what is it.
I will post also my youtube video with the strange noise coming from the hhod,which happens sometimes when i hit the gas pedal.
Reason: Video link
Reason: Video link
- My Cars: Citroen C5 Estate 2009
- x 13
Re: C5 x7 2.0hdi 103kw,2011year stagger when hit the gas and strange noise
Hi
Thank you for posting this, I have the same issue with the same noise occasionally but have been unable to catch it on video.
Regards
Steve
Regards
Steve
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
It almost sounds like a 'rasping' noise, indicative of a turbo hose leak / split, more noticeable when giving the car some throttle.
Exactly.Hope it is not turbo itself.GiveMeABreak wrote: ↑29 May 2021, 09:17 It almost sounds like a 'rasping' noise, indicative of a turbo hose leak / split, more noticeable when giving the car some throttle.
- x 13
Hi
No I haven't found out what causes it but I have worked out that if you put supermarket diesel in it is much more frequent.
Regards
Steve
Regards
Steve
Thanks for the reply Steve.
I will take my car for sure to the authorised Citroen service,as I cannot find the solution for the issue.
Best
Best
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
I wonder what would happen if you were to use some main distributer fuel (such as Esso or Shell) with some injector cleaner in the tank? I bought three bottles from ebay not so long back;
https://www.ebay.co.uk/itm/143927389437 ... 2749.l2649
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Hi
Thanks for answering.
For the fact I live in Bosnia I do not have possobility for Esso or Shell fuel.
I had already tried with injector cleaner,bit not the one you mentioned.I havent seen any difference in the car behaviour.
Best
Best
- Donor 2023
- x 3008
OK, so what I meant (by the fuel, that is) is to use some fuel from a main supplier as opposed to that from a supermarket. One of the reasons supermarket fuel is cheaper is that there are fewer 'useful' additives in it, and your car may be finding that to be a problem.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- x 13
Good morning all
I too have tried injector cleaner to no avail, I find if you are gentle with the accelerator pedal through a certain rev range say between 1200 / 2000 rpm it is not as frequent / noticeable.
Like I said in an earlier post Morrisons fuel sometimes makes it worse but not every time you fill up which is strange unless they purchase from different suppliers.
I find Shell or BP seem to help but not cure the issue.
I sort of compare the issue to a type of pinking In older petrol engines (just my take on it)
I would appreciate an update if anyone manages to get to the cause of the issue..
Just as a footnote, I have no warning lights illuminated on the car.
Regards
Steve
Regards
Steve
Yes,I hear you.I am using only best possible fuel.Hell Razor5543 wrote: ↑29 May 2021, 22:52 OK, so what I meant (by the fuel, that is) is to use some fuel from a main supplier as opposed to that from a supermarket. One of the reasons supermarket fuel is cheaper is that there are fewer 'useful' additives in it, and your car may be finding that to be a problem.
I will have taken my car to the citroen dealership next month.I will keep you posted for any solution they might find.Steveo wrote: ↑30 May 2021, 07:49 Good morning all
Regards
Steve
I was today at garage my friend told me about.
The mechanic said to me the problem is EGR( little bit clogged ) and need to replace washers on injectors.
So,my next step is to do that.
- x 13
Hi
EGR may be the issue in regards to cleaning but I cannot see it being the copper washers at the base of the injectors as its not chuffing (blow back through copper seal) and no leak or smell of diesel.
But maybe the EGR does want cleaning
Thank you again
Regards
Steve
Thank you again
Regards
Steve
