water leak into the trunk c5 x7
amigo
I have found water leaking into the cabin on my c5 but i cant find where the water is going in from, do any know where to search ? its leaking out between the 2 metal plates.
Larsanjus
Re: water leak into the trunk c5 x7
I would suspect the rubber grommet near the hinge where all the wires and hoses go to the hatch.
Especially the body side end. I'v had two C4s leaking from there, luckily no C5 leaking so far.
Are you sure it is water and not washer fluid?
amigo
yes its water, we have had alot rain this week and the leak stops with the rain, i have found a broken rubber grommet (the little one at the hatch with 3 wires) maybe its going in that way.Larsanjus wrote: 24 May 2021, 19:42 I would suspect the rubber grommet near the hinge where all the wires and hoses go to the hatch.
