Slightly rough start + smoke, not great at low revs
Euanatkinson
Unread post by Euanatkinson »
Hi everyone,
I bought a 1.6 Citroen Berlingo Swb van a few weeks back. It’s had full service with new cam belt, breaks, tyres etc, seemed like a solid buy at 100k miles
I didn’t notice when I went to see it but on the first start of the day it’s kicking out a fair bit of white smoke. It also sounds slightly rough when starting up. when hill starting on a steep hill it seems very sluggish and hesitant but will then kick into action and on a few occasions when reversing on a steep hill it’s also kicked out some black smoke a few times
I bought it privately but with full service history and On previous MoTs it has failed Exhaust emissions tests.
It’s been for a check out at a Citroen dealer and they suggested I took it for a bomb down the motorway as it’s most likely been used for stop start driving so I did that yesterday, but seems similar today.
Any advice on what to do here?
Thanks a lot
Dormouse
x 696
Re: Slightly rough start + smoke, not great at low revs
Unread post by Dormouse »
my ducato did that and it returned a fuel rail set of errors. cleared the faults and it is running fine. Passed it's MOT. It has stood unused a lot (and still does) so I am not exactly sure what caused it. Get a set of readings downloaded and see what shows up. If your problem is fuel pressure sensor related then there are lots of potential helpers here. There are other possibilities too.
moizeau
x 429
Unread post by moizeau »
Does it bring up the MIL?
Pete
Dormouse
x 696
It did on my van. It has behaved since but the van is not moving much at the moment. Not convinced I won't have to do more.
moizeau
x 429
Mine was the egr, very strong smell of diesel when cold, OK when warmed up.
Pete
Dormouse
x 696
That is what I actually suspect too. Pint Pot, as the van is called, had a short engine fitted 35000 miles ago and I am certain nothing else was replaced. Torn ligaments in my knee is stopping me from tearing things apart at the moment. I can't hear a clear EGR cycle after I switch off but I am going to service a whole host of things before Pint Pot is finished.
Dormouse
x 696
Sorry Euan for hijacking your thread. EGR is a possibility but I would ask everyone else out there to come back to you with their thoughts. Fault codes are still a handy thing.
Dormouse
x 696
While you are waiting for other replies Euan, try a reputable diesel additive to help clean the EGR and other parts of the engine. Yes, getting the whole engine and exhaust completely hot for a good 30 minutes plus is a good thing. Pootling about will never get the complete set up "warm". By hot I don't just mean getting the temperature gauge up, I mean hard driving to raise the complete system above normal and no I don't mean thrash it. There is a difference.
x 3306
There is what is known as "An Italian Tune Up". This is taking the vehicle out for a long FAST drive (at least 30 minutes) to allow the vehicle to properly 'clear her throat'. If I am taking my vehicle for an MoT (as opposed to getting others to do it) I will make sure to get her nicely warmed up, as this will certainly help with the emissions test (as a warmed up engine produces less soot than a cold one).
I have used Wynns Diesel Injector Cleaner on every vehicle I have owned on the first tank of fuel I put in them. As I don't know how they have been driven before I got them I want to help clear their pipes. I bought three bottles from ebay recently for £14, which is quite a saving. You put ONE bottle into a full tank (I put it in before adding the diesel, as this will ensure it gets properly mixed into the fuel).
https://www.ebay.co.uk/itm/143927389437 ... 2749.l2649
Dormouse
x 696
Loading the vehicle with extra weight (not overloading it) and finding a long steady incline/open hill to power up will "heat" the engine system up better than a run on the level. Not always easy to find for people in an urban area.
