C8 2.2HDi 170 Codes P1351 and P1447
Peter Morgan
(Donor 2021)
Unread post by Peter Morgan »
Hi All,
Looking for some suggestions before the trusty C8 gets towed away
As with many, long history of 'depollution fault' messages with the car. The second dpf was fitted at 160K miles as Citroen main dealer said dpf was more than 50% full and would need replacing soon anyway. Fault continued together with P0299 (pressure/air problem, I seem to recall). So, 2 new turbo sensors were fitted and this got rid of that code. However, antipollution fault message continued and car in limp mode. Dealer has now said that dpf is fine and there must be an 'electrical problem' and suspect that the ECU needs changing. Apparently uneconomic and in fact they were unable to source one.
Also changed in recent months - fuel filter
The P1351 code also exists - glowplugs? - but I believe that's quite common and there are no starting issues.
Can anyone suggest a work-round or further possible courses of action. The dealer suggested that a specialist could trick the ECU to ignore dpf messages - could this work. They said they couldn't (as a main dealer) have that done for me, but I may be able to find someone willing to do
Any words of wisdom gratefully received. Other than this, the car would continue for many more miles, I think
TIA
x 6950
Re: C8 2.2HDi 170 Codes P1351 and P1447
The glow plugs are not only used for assisted starting in cold weather, they are also used by the engine ECU in assisted regeneration to help raise the temperature more rapidly, along with the operation of consumer electrical devices such as the heated rear windscreen for example. There are generally 2 errors - one where the relay is at fault and one where one or more glow plugs are not operating. So yes, they are not really required for starting in an HDi engine, but do have other uses.
What other fault codes have you now got coming up apart from the P1351? There should be another fault code stored if the engine ECU deems it necessary to put the engine into a back up mode.
Peter Morgan
(Donor 2021)
Hi Marc - Thanks for your response - sorry, per the heading, p1447
Best regards
x 6950
Sorry - couldn't see the wood for the trees.
P1447: Differential exhaust pressure signal: Clogged particle filter. Ok, so this fault is telling you that the difference in pressure entering and leaving the particle filter means that it is getting clogged or is blocked.
So the question is how many miles has the vehicle done? The particle filter may be at end of life - so may need a deep clean.
Has the vehicle been getting a good run lately?
Until resolved though, I would not drive the vehicle unnecessarily as if it is indeed getting blocked it is going to prohibit engine performance to the point the engine will start cutting out if it gets too bad.
Normally the regeneration should take care of the soot - but over time the ash and Cerine particles which cannot be burnt off will clog the filter. It is this that ultimately requires a deep clean or replacement of the particle filter.
Peter Morgan
(Donor 2021)
Marc, the dealership fitted a new dpf - but say the ECU won't recognise it as such and they cannot get the message to disappear or the car out of 'limp' mode (EML on too). They also found a split intercooler to turbo pipe which apparently is not available (so it has been taped up), I have no idea why it split as it is split on top, not underneath
Thanks for your help
GeorgeCDLC
Unread post by GeorgeCDLC »
Hi all, posting here as I have a similar issue.
Citroen jumpy 2014 with p1447 p1490 p135 warning light and engine light on. 22000km and 247000mg of particle fluid. Would you recommend trying a long drive at 40mph as I have seen on other posts? Not sure of the severity considering the engine light being on.
Thanks in advance and happy to post/ask somewhere else if not related to the thread :)
x 1083
Unread post by Rp0thejester »
If it's a C8, rag the hell out of it. If not, I wouldn't recommend it but it could work. As for the EML it's probably just a warning that it needs attention. But if it goes to an MOT with an EML it will fail, unless it's an 06 or before
Peter Morgan
(Donor 2021)
An update from me - the issue could not be resolved by the main dealer - so the dpf was removed, ECU recoded and he still lives (207K miles now)
