I have a fault with the aircon in my 2010 X7 3.0 HDi - in that the button lights up happily but the compressor doesn't engage.
I've checked the cooling fans on an actuator test and they both run perfectly. I've also checked the compressor engagement and that test completes successfully (without error). I can't hear an obvious click, although I'm not sure I ever did on this car when it was working ok and there's a fair bit of ambient noise around here.
The air con pressure is showing as 5.6bar (I don't know if that's good or bad?). When aircon is activated, the "status" in the Engine ECU live data changes from "No aircon request" to "Air condition request: Authorisation refused by engine ECU".
Can anyone shine a light on what the pressure ought to be showing, and whether it might be refusing to engage because of low pressure? If that's a workable value, I'll have to look deeper into the compressor clutch.
Thanks!
C5 X7 Aircon Compressor not engaging
- My Cars: 2010 C5 V6 HDi Tourer
2006 307SW HDi 136
1992 205 GRDT - x 3
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: C5 X7 Aircon Compressor not engaging
If the gas is low the compressor will be automatically shut off to prevent damage. You'll probably need a top up or if you have recently, then you may have a leak. Most common is the condenser radiator at the front that gets 'stone chipped'.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
There is low and high pressure to be checked with engine stationary and engine running.
If the High pressure (at 20℃) is lower than 6 BAR or lower than 7 BAR at 25℃ and the Low pressure is lower than 2.4 BAR then you have a lack of refrigerant.
2006 307SW HDi 136
1992 205 GRDT - x 3
Thanks Marc! The value I have is from engine ECU live data, reading 5.6bar with engine running at idle and it's just labelled "Air conditioning circuit pressure".
I just don't want to go get a regas and then find the compressor clutch is knackered and have to get it done all over again!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's the same problem I have with our other C3, except that ATS re-gassed it last year and it is running warm now - so I suspect a leak and the only way to find that is getting dye in for investigation....
- My Cars: 2012 C5 Citroen 3.0L HDI
- x 4
It was the clutch that failed in our 3.0 HDI C5, but I am not sure whether it is the same problem in your car? viewtopic.php?t=67103
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
5.6 bar should be plenty of refrigerant. If you have access to diagbox, you should be able to see if the compressor clutch is being activated, and if not, there should be a fault code or sensor state that is disabling it. Also check the engine ECU fault codes, as some will disable the a/c compressor.lorddevereux wrote: ↑23 Apr 2021, 11:54 Thanks Marc! The value I have is from engine ECU live data, reading 5.6bar with engine running at idle and it's just labelled "Air conditioning circuit pressure".
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I already checked the specs Mike and officially if under the pressures I stated - that is the diagnosis.
2006 307SW HDi 136
1992 205 GRDT - x 3
Cit fan 151 wrote: ↑23 Apr 2021, 22:45 It was the clutch that failed in our 3.0 HDI C5, but I am not sure whether it is the same problem in your car? viewtopic.php?t=67103
Thanks! It's looking like it is the clutch as I'm pretty sure there's no click from the actuator test at all. Looks like it may be possible to unbolt with the compressor still attached (i.e without requiring the hoses disconnected?)
- x 4
The diagnosis for our C5 was a Clutch Control Fault - C994. The dealer wanted to replace compressor, condenser and regass.
As I was unsure whether the clutch could be separated from compressor on our model (not sold separately by dealer), I ended up buying a 'remanufactured' compressor. The mechanic simply swapped the clutch from the 'remanufactured' compressor to the one on the car and hence no regassing was required. That was a few months ago and it has been fine since.
I have since done some research on obtaining the clutch only, so I can attach it to my spare compressor (if necessary). It is important to identify which Sanden compressor you have on your car - I understand this information is available from Servicebox for a nominal fee?
I was advised by the supplier of the following clutch that it was the right one, based on the compressor details I provided for our car https://www.aliexpress.com/item/1005002297371884.html I am not able to confirm it is the correct one, or what the quality of it is, but it certainly is much cheaper (and environmentally friendly) than the original solution I was offered for a failed AC clutch!
- Gregor
- My Cars: Actual fleet:
- C5 III tourer 2.0 HDI RHF (103kW 2010)
- P208 XY 1.6 THP (115kW 2013)
- GSX-R 750 (110 kW 2008)
Past members:
Xsara 2.0 VTS (2001)
P206 1.4 XS (1999)
AX 1.1 (1991)
R 5 GT-turbo (1988)
Visa 11 RE (1984)
GS 1.3 Super (1979)
R 12 TL (1975)
Zastava 750 (1968) - x 14
99% of non working A/C 's is caused by leak of R-134a. Find a service guy for refrigerators to fill you a small amount (100g) and it will almost certainly start working.
BR G
BR G
Driving Citroen is a diagnose!
