X7 front suspension leak
x 6953
Re: X7 front suspension leak
Have you checked the fluid level yet?
Put the car on lowest suspension on lowest setting to check on level ground:
The levels should be between the 'A' & 'B'
If the levels are correct, you may have a problem with the height corrector (s). Raise and lower the car several times Max to Min to 'work' the height correctors.
mypinknee
(Donor 2021)
x 11
Unread post by mypinknee »
Thanks - it looks like it might be a fluid level problem. I should have checked.
I have some old LHM fluid made by Castrol. It says "New Formula" and that it is for hydraulic reservoirs marked LHM or LHM Plus.
It also says to B712710. Mind you it must be over ten years old, so I should probably get something newer!
;-D
GiveMeABreak wrote: 12 Apr 2021, 09:51 Have you checked the fluid level yet?
My other car is a 2cv
x 6953
Never use LHM or LHM Plus fluid in a C5!
The C5 uses Total LDS or Total Fluide DA exclusively - never use the green mineral fluid used in earlier systems it is not designed for these systems....
mypinknee
(Donor 2021)
x 11
Well if there is someone near me who would like about 650ml of green LHM - they are very welcome.
My postcode is *******
GiveMeABreak wrote: 12 Apr 2021, 16:04 Never use LHM or LHM Plus fluid in a C5!
Reason: Personal details removed - Please contact OP via Private Message if Interested
