Can I get an independent diagnosis? Reading other posts there seems to be different kinds of diagnoses.
Is there anyone near me in West Gloucestershire who might be able to help.
The reason I ask is because my car has pretty faultless since I first drove it on January 1st 2011 - except for one thing - the boot won't always close or open electrically.
After a while I realised this might have something to do with either the economy mode or low voltage from the battery. After 3 years I was having starting problems because the battery was failing to take a charge and so the it was replaced under warranty.
Now 5/6 years later the problem started again. I have only done 55,000 miles and the car sometimes isn't used for a few days.
I took it to my local dealer who diagnosed an alternator fault. The battery was checked and found to be okay. They believed the alternator was not supplying sufficient current. I was told there had never been any official software updates for my ca and quoted £697 for a genuine new Citroen alternator or £391 for compatible one - both plus VAT. So I booked it in for the less expensive one. At the same time I made a request for help from Citroen on the basis there had been a fault with the alternator since the car was new. Yes - I am an optimist, and no they wouldn't contribute anything.
The car was examined and upon further investigation the garage found that there was a software update - which they did. This reset the charging rate for the alternator, so it was not replaced - I was happy about that!
I took the car away and found they had managed to lose the radio and remote control of the boot. I left it for a week while I was on Skokholm, came back to a flat battery. I got a jump start. Drove home and the next day decided I would replace the battery. This has been done and it is still early days to tell if the problem is now solved.
Is there any link between needing to recode the radio and the remote for the boot not working? The boot does open electrically - it is just the remote opening that has stopped working. Should fixing it take much time? Could I do it myself or is the garage responsible for making it work.
All comment gratefully received.
