Hello out there,
Does anyone have any idea where I should start looking for faults;
MAF ?
O2 sensor ?
Dunno where to start !
C5 2.0hdi 136hp P1461 fault code
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5648
Re: C5 2.0hdi 136hp P1461 fault code
I take it this is the 2.0 138 (DW10BTED4), not the 2.2 136?
Fault Code: | P1461 |
Description of Fault: | Electric EGR valve position copy signal: Difference between the stops programmed at long-term. Slow or rapid drift on initialisation of the EGR bottom stop for 100 ms |
Conditions for Fault to clear: | Driving for 5 minutes |
Downgrade Modes whilst Fault is active: | Exhaust gas recycling (EGR) cut-off Initialisation the next time the engine ECU goes to sleep |
Symptoms: | Engine hesitating, cutting out Smoke from the exhaust Starting problem |
Suspect Areas: | Electrical harness Connector Electric exhaust gas recycling valve |
- My Cars: BX'S, XM, ZX, XANTIA'S, C5
Hiya Marc, thanks for reply. Yes its the same as your C5 II only gold, not black.
Symptoms; starts fine, haven't noticed excessive smoke, all is fine until engine up to temp, then, almost no boost.
Feels like a pre-turbo diesel like an old ZX I used to have.
Still have no idea where to start looking, HEEEEELP !
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Check the thermostat - is the car gauge showing heating up normally or too fast? If the engine ECU thinks the car is overheating it may stop the turbo boost - especially as you say this is happening when the car is up to temperature.
I'd check ALL your vacuum hoses for leaks and all your turbo hoses too - make sure they aren't kinked or sticking together when hot.
will do thanks
