wanting a tailgate wiring diagram for 2007 restyle C5
davidc
(Donor 2021)
Unread post by davidc »
Hello
Having problems with 'gate not unlocking, have tried different lock and switch (from a working Series 1, seem identical) so after a wiring diagram if available. VIN VF7**************[VIN obfuscated, can be read by forum staff].
Thank you.
2007 C5 hdi Wagon
74 D Special
2009 Mercedes Benz ML 320 cdi
x 6945
Re: wanting a tailgate wiring diagram for 2007 restyle C5
Here you go - there's not one for the tailgate per se, but as it's the tailgate lock that forms part of the central locking, here is the diagram for the complete Central Deadlocking system:
Note: Don't use the wiring colours - use the Pin number on the connectors as PSA frequently change the colours - and as you can see on the wiring diagram 'ND' effectively means non descriptive for the colour, so could be anything.
6283: Tailgate opening switch
6284: Tailgate window locking actuator /
If you need any more component codes, they are on our Wiki in ascending order of numbers:
Electrical Component Codes
...and here is the location diagram of the various harnesses and earthing points:
...and lastly the actual wiring diagram showing the harnesses and interconnections:
davidc
(Donor 2021)
Hey that is fantastic much appreciated!
2007 C5 hdi Wagon
74 D Special
