Total transmission gear 8 vs Mobil gear oil FE 75w
rvca
Unread post by rvca »
With the change of the transmission shaft, I lost some oil and i need to correct the level.
Being a citroen c3 1.1cc from 2004, I couldn't find the screw that allows me to see the oil level, so I decided to replace it.
When I looked to the car manual for the original oil I realized that it was replaced by Total transmission gear 8 (Gl4 +).
However, when trying to buy it at the parts store where I am a customer, I was advised to buy the (PSA) Mobil gear oil FE 75w (see image attached) (B712310 / Gl4).
The question is.. which of the two will be the best for the gearbox?
Thank you
x 8251
Re: Total transmission gear 8 vs Mobil gear oil FE 75w
In my experience, all PSA gearboxes are very fussy about having the correct oil in them...
I would source the proper Total BV 75W/80 and not risk anything else...
Comma offer a good substitute...
x 1751
The correct spec for the manual gear oil is Peugeot-Citroen B71 2330
Total Transmission 8 gear oil 75W80 GL-4 is what Citroen workshops have been using, often supplied to them in bulk
Total recently rechristened this as Total Traxium gear oil 75W80 GL-4
Both of these conform to the B71 2330 spec.
Any reliable brand of this spec should be good.
rvca
Thanks for the answers.
I am of the same opinion, and I was determined to buy the Total Transmission gear 8.
The store technician suggested this mobil made for the psa group ... and I was confused... Mainly because of this B712310 spec.
x 6963
Also see this post regarding the gearbox Oil filling:
viewtopic.php?p=674498#p674498
